Hi!
I´m getting this Fatal Error message very often.
It all starts with a message that says I´m out of memory, then this message shows up.
The Task manager (performance) in windows says that there is a lot of memory, there must be something in AutoCad that controls this?
Any ideas?
The attached JPG is a screen dump that shows the message and the task manager (in swedish).
// Tobias
Could you post the contents of the error message? I'm having trouble reading it.
Have you downloaded and installed the latest service pack?
What are you doing or attempting to do when the error occurs?
Does it happen consistently at the same point in the drawing each and every time?
Is the error specific to one drawing or does it happen in multiple drawings?
Here´s the error text:
Unhandled Acess Violation Reading 0x0334 Exception at 607b9dfah
I have the latest Service pack installed.
This time I was only trying too open one more drawing, I had 3 other drawings open before the error occured. They were not so big only about 1 mb. So the answer Is no to the next question, It does´nt happen each and every time in the same drawing.
It is different drawings every time!
Thanks for trying too help, and excuse me for poor english.
//Tobias
Does the error occur mainly when you open, close or try to save a drawing?
Your English is fine. If it becomes a problem for me I'll let you know.
It happens mainly when I try to open another file.
//Tobias
  • 4 weeks later...
Hallo!
My Cad and computer support probably solved this issue.
It has not happend after he did this.
Updated windows Net framework 3.0 to 3.5
Changed the 3D device to an older certified version.
This also made other things faster, changing between layout tabs for example.
Just wanted to tell you this!
//Tobias
Tobias: Thank you for updating us on the status of your problem. It may be of interest to others with similar problems.
