hi all, maybe i'm going crazy, don't use CAD too often but I am sure I am able to insert coordinates Easting and Northing without actually typing them?
For example, I have  287858.66,1779156.28  and I remember I can just copy this string, then typle "C" in CAD , and when promped to specify the center, I can paste this string and the Circle
gets inserted there, shouldn't it?
By the way this is part of a  large task that I will add to the payment service shortly.
thank you
Alex
When doing this you must select the right end of the command line prompt if you do just C Ctrl+V it will fail.
Select center of circle or [2 Point/3 Point/Tangent-Tangent-Radius/turn Arc into circle/Multiple circles]:287858.66,1779156.28
