Aftertouch Posted March 12, 2024 Posted March 12, 2024 Hi all, Is there a way to check if a hatch has a 'spline' boundary? When i check the data of a regular hatch, and one created with a spline. i find the following DXF groups are diferent: (93 . 1) (72 . 4) (94 . 3) But i cannot find any documentation about those DXF numbers? Quote
lastknownuser Posted March 12, 2024 Posted March 12, 2024 38 minutes ago, Aftertouch said: Hi all, Is there a way to check if a hatch has a 'spline' boundary? When i check the data of a regular hatch, and one created with a spline. i find the following DXF groups are diferent: (93 . 1) (72 . 4) (94 . 3) But i cannot find any documentation about those DXF numbers? Check this https://filemonger.com/specs/dxf/wotsit.org/dxf_r14/boundary_path_data_al_u05_c.htm With group code 72 you could probably do what you want Quote
