Can you give me 5 to 10 command for draw,modify,dimensions ?
e.g.) draw-line,arc
e.g.)modify-trim,copy
e.g.)dimensions-linear
Thank you
Welcome to the forum. Not sure I follow. What is this? homework? :)
Here are some commands to draw and/or modify dimensions off the top of my head:
DIM
DIM1
DIMLINEAR
DIMALIGNED
DIMORDINATE
DIMANGULAR
DIMRADIUS
DIMEDIT
DIMTEDIT
DIMASO (discontinued I believe)
DIMASSOC
DIMDISSASOCIATE
DIMREASSOC
Or go to ACAD help, command reference.
I assume you have access to the program, can't you just click the name (ie Draw) on the menu bar and choose 5 or 10 of the commands you see?
I think it may be three separate categories. Right?
Draw: line, poyline, arc, circle, ellipse, polygon, rectangle....
Modify: erase, copy, mirror, offset, array, move, rotate....
Dimension: aligned, linear, center, angular, diameter, radius....
Who gets the actual grade for this? You or us?
^ I think you are right as usual, ReMark. You get an A+
Also OP: Note that technically, you could put the DIM command in all three categories!
e.g.) draw-line,arc
Thank you
Thanks everybody for your help :)
I guess he got his homework assignment done. Now he can go out and party or sequester himself in his room the remainder of the day listening to his iPod and playing Grand Theft Auto XXX.
You're probably right ReMark, which is why I don't reply to questions like this anymore.
"Can you give me 5 to 10 command for draw,modify,dimensions"
If that's not a textbook homework question, then I don't know what is? :P
I fell for this one straight-away. That must make me the sucker-of-the-day. Normally I feel as you do Cad64. I don't mind giving advice but I also try not to do the assignment in the process of doing so.
I would be willing to bet his post count remains at 2 for a long time... or at least until he gets stuck on his next assignment
Not sure why he is posting the question - I thought all the commands were labelled under certain headings in the menu's...
