Good morning, before delving into fruitless research, I ask you if it is possible to compile the attributes of selected blocks in a data extraction, by compiling the autocad table that is generated at the end of the extraction... therefore a sort of reverse data extraction.
Thank you in advance
Some one did ask for a 2 way update method but if I remember correctly it makes a circular solution so its not supported in CAD. Pick an atrribute table updates, uses fields. Like wise pick a cell attribute updates but no 2 way.
