dcandmc Posted March 5, 2009 Posted March 5, 2009 OK, I understand that "fillet" the original was designed for lines arcs and basic objects. AEC Fillet command "aecfillet" is designed for AEC objects. Now at work (I have not asked) I don't have to make that distinction the command "f" works for everything. How can I get that to work on my machine? Architecture 2009 & Plenty of computing power to run it. Thanks Derek Quote
luther4000 Posted March 9, 2009 Posted March 9, 2009 If what you want is "f" to call the AECfillet command, you can modify the Alias for "f' to point to AECFILLET instead of FILLET. I don't know the AECFILLET command very good, but as far as i am concerned FILLET does work with WALLS and other AEC Objects. Quote
