mhy3sx Posted March 17, 2024 Posted March 17, 2024 Hi . I use this code to insert table from txt with coordinates in the drawing. I want to ask if is any way to round up the coordinates to 2 or 3 decimal places before insert because the txt file some times have the coordinates to 8 decimal places like the example 1,311159.96991560,4244183.67645809,4.631 2,311162.47527926,4244177.41308898,5.156 3,311165.60772520,4244171.78492820,5.751 4,311168.98863420,4244168.37002316,6.080 5,311173.45298218,4244165.91270090,6.768 6,311177.82803504,4244162.50450169,7.273 7,311169.80214645,4244164.70754902,6.584 8,311167.89884639,4244165.03704983,6.369 9,311166.02291493,4244164.79504988,6.281 10,311162.84830354,4244162.21893261,6.324 11,311159.10740377,4244157.54691043,6.367 12,311155.00796711,4244160.54083855,5.877 The code I use is ;; Text File to Table - Lee Mac ;; Prompts the user to select a text file containing 4 columns of comma-delimited data ;; and generates an AutoCAD Table containing the file data at the point specified. (defun c:foo ( / *error* des ins lin lst txt ) (defun *error* ( msg ) (if (= 'file (type des)) (close des)) (if (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*")) (princ (strcat "\nError: " msg)) ) (princ) ) (if (setq txt (getfiled "Επιλέξτε το αρχείο P,X,Y,Z (*.txt)" "" "txt" 16)) (if (setq des (open txt "r")) (progn (while (setq lin (read-line des)) (if (= 4 (length (setq lin (LM:str->lst lin ",")))) (setq lst (cons lin lst)) ) ) (setq des (close des)) (if lst (if (setq ins (getpoint "\nSpecify point for table: ")) (LM:addtable (vlax-get-property (vla-get-activedocument (vlax-get-acad-object)) (if (= 1 (getvar 'cvport)) 'paperspace 'modelspace ) ) (trans ins 1 0) nil (cons '("A/A" "X" "Y" "Z") (reverse lst)) nil ) ) (princ "\nNo valid data found in selected file.") ) ) (princ "\nUnable to open selected file for reading.") ) ) (princ) ) ;;---------------------=={ Add Table }==----------------------;; ;; ;; ;; Creates an AutoCAD Table Object at the specified point, ;; ;; populated with the given data and optional title. ;; ;;------------------------------------------------------------;; ;; Author: Lee Mac, Copyright © 2013 - [url]www.lee-mac.com[/url] ;; ;;------------------------------------------------------------;; ;; Arguments: ;; ;; spc - VLA Block Object ;; ;; ins - WCS Insertion Point for Table ;; ;; ttl - [Optional] Table title ;; ;; lst - Matrix list of data to populate the table ;; ;; eqc - If T, columns are of equal width ;; ;;------------------------------------------------------------;; ;; Returns: VLA Table Object ;; ;;------------------------------------------------------------;; (defun LM:AddTable ( spc ins ttl lst eqc / dif hgt i j obj stn sty wid ) (setq sty (vlax-ename->vla-object (cdr (assoc -1 (dictsearch (cdr (assoc -1 (dictsearch (namedobjdict) "acad_tablestyle") ) ) (getvar 'ctablestyle) ) ) ) ) ) (setq hgt (vla-gettextheight sty acdatarow)) (if (LM:Annotative-p (setq stn (vla-gettextstyle sty acdatarow))) (setq hgt (/ hgt (getvar 'cannoscalevalue))) ) (setq wid (mapcar (function (lambda ( col ) (apply 'max (mapcar (function (lambda ( str ) ( (lambda ( box ) (if box (+ (* 2.5 hgt) (- (caadr box) (caar box))) 0.0)) (textbox (list (cons 01 str) (cons 40 hgt) (cons 07 stn) ) ) ) ) ) col ) ) ) ) (apply 'mapcar (cons 'list lst)) ) ) (if (and ttl (< 0.0 (setq dif (/ (- ( (lambda ( box ) (if box (+ (* 2.5 hgt) (- (caadr box) (caar box))) 0.0)) (textbox (list (cons 01 ttl) (cons 40 hgt) (cons 07 stn) ) ) ) (apply '+ wid) ) (length wid) ) ) ) ) (setq wid (mapcar '(lambda ( x ) (+ x dif)) wid)) ) (setq obj (vla-addtable spc (vlax-3D-point ins) (1+ (length lst)) (length (car lst)) (* 2.0 hgt) (if eqc (apply 'max wid) (/ (apply '+ wid) (float (length (car lst)))) ) ) ) (vla-put-regeneratetablesuppressed obj :vlax-true) (vla-put-stylename obj (getvar 'ctablestyle)) (setq i -1) (if (null eqc) (foreach col wid (vla-setcolumnwidth obj (setq i (1+ i)) col) ) ) (if ttl (progn (vla-settext obj 0 0 ttl) (setq i 1) ) (progn (vla-deleterows obj 0 1) (setq i 0) ) ) (foreach row lst (setq j 0) (foreach val row (vla-settext obj i j val) (setq j (1+ j)) ) (setq i (1+ i)) ) (vla-put-regeneratetablesuppressed obj :vlax-false) obj ) ;; Annotative-p ;; Returns T if the given Textstyle is annotative (defun LM:annotative-p ( sty ) (and (setq sty (tblobjname "style" sty)) (setq sty (cadr (assoc -3 (entget sty '("AcadAnnotative"))))) (= 1 (cdr (assoc 1070 (reverse sty)))) ) ) ;; String to List ;; Separates a string using a given delimiter ;; str - [str] string to process ;; del - [str] delimiter by which to separate the string (defun LM:str->lst ( str del / pos ) (if (setq pos (vl-string-search del str)) (cons (substr str 1 pos) (LM:str->lst (substr str (+ pos 1 (strlen del))) del)) (list str) ) ) (vl-load-com) (princ) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;;----------------------=={ Text File to Table }==----------------------;; ;; ;; ;; Prompts the user to select a text file and generates an AutoCAD ;; ;; Table at the point specified, representing the file data. ;; ;;----------------------------------------------------------------------;; ;; Author: Lee Mac, Copyright © 2013 - [url]www.lee-mac.com[/url] ;; ;;----------------------------------------------------------------------;; (defun c:txt2tab2 ( / *error* del des hdl ins lin lst txt ) (setq ttl nil ;; Table Title (nil for no title) hdl '("A/A" "X" "Y") ;; Table Headings del "," ;; Data Delimiter String ) (defun *error* ( msg ) (if (= 'file (type des)) (close des)) (if (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*")) (princ (strcat "\nError: " msg)) ) (princ) ) (if (setq txt (getfiled "Επιλέξτε το αρχείο P,X,Y (*.txt)" "" "txt" 16)) (if (setq des (open txt "r")) (progn (while (setq lin (read-line des)) (setq lst (cons (mapcar '(lambda ( a b ) a) (LM:str->lst lin del) hdl) lst)) ) (setq des (close des)) (if lst (if (setq ins (getpoint "\nSpecify point for table: ")) (LM:addtable (vlax-get-property (vla-get-activedocument (vlax-get-acad-object)) (if (= 1 (getvar 'cvport)) 'paperspace 'modelspace ) ) (trans ins 1 0) ttl (cons hdl (reverse lst)) nil ) ) (princ "\nNo valid data found in selected file.") ) ) (princ "\nUnable to open selected file for reading.") ) ) (princ) ) ;;---------------------------=={ Add Table }==--------------------------;; ;; ;; ;; Creates an AutoCAD Table Object at the specified point, populated ;; ;; with the given data and optional title. ;; ;;----------------------------------------------------------------------;; ;; Author: Lee Mac, Copyright © 2013 - [url]www.lee-mac.com[/url] ;; ;;----------------------------------------------------------------------;; ;; Arguments: ;; ;; spc - VLA Block object ;; ;; ins - WCS Insertion point for table ;; ;; ttl - [Optional] Table title ;; ;; lst - Matrix list of data to populate the table ;; ;; eqc - If T, columns are of equal width ;; ;;----------------------------------------------------------------------;; ;; Returns: VLA Table Object ;; ;;----------------------------------------------------------------------;; (defun LM:AddTable ( spc ins ttl lst eqc / dif hgt i j obj stn sty wid ) (setq sty (vlax-ename->vla-object (cdr (assoc -1 (dictsearch (cdr (assoc -1 (dictsearch (namedobjdict) "acad_tablestyle") ) ) (getvar 'ctablestyle) ) ) ) ) ) (setq hgt (vla-gettextheight sty acdatarow)) (if (LM:Annotative-p (setq stn (vla-gettextstyle sty acdatarow))) (setq hgt (/ hgt (getvar 'cannoscalevalue))) ) (setq wid (mapcar (function (lambda ( col ) (apply 'max (mapcar (function (lambda ( str ) ( (lambda ( box ) (if box (+ (* 2.5 hgt) (- (caadr box) (caar box))) 0.0)) (textbox (list (cons 01 str) (cons 40 hgt) (cons 07 stn) ) ) ) ) ) col ) ) ) ) (apply 'mapcar (cons 'list lst)) ) ) (if (and ttl (< 0.0 (setq dif (/ (- ( (lambda ( box ) (if box (+ (* 2.5 hgt) (- (caadr box) (caar box))) 0.0)) (textbox (list (cons 01 ttl) (cons 40 hgt) (cons 07 stn) ) ) ) (apply '+ wid) ) (length wid) ) ) ) ) (setq wid (mapcar '(lambda ( x ) (+ x dif)) wid)) ) (setq obj (vla-addtable spc (vlax-3D-point ins) (1+ (length lst)) (length (car lst)) (* 2.0 hgt) (if eqc (apply 'max wid) (/ (apply '+ wid) (float (length (car lst)))) ) ) ) (vla-put-regeneratetablesuppressed obj :vlax-true) (vla-put-stylename obj (getvar 'ctablestyle)) (setq i -1) (if (null eqc) (foreach col wid (vla-setcolumnwidth obj (setq i (1+ i)) col) ) ) (if ttl (progn (vla-settext obj 0 0 ttl) (setq i 1) ) (progn (vla-deleterows obj 0 1) (setq i 0) ) ) (foreach row lst (setq j 0) (foreach val row (vla-settext obj i j val) (setq j (1+ j)) ) (setq i (1+ i)) ) (vla-put-regeneratetablesuppressed obj :vlax-false) obj ) ;; Returns T if the given Textstyle is annotative (defun LM:annotative-p ( sty ) (and (setq sty (tblobjname "style" sty)) (setq sty (cadr (assoc -3 (entget sty '("AcadAnnotative"))))) (= 1 (cdr (assoc 1070 (reverse sty)))) ) ) ;; String to List ;; Separates a string using a given delimiter ;; str - [str] string to process ;; del - [str] delimiter by which to separate the string (defun LM:str->lst ( str del / pos ) (if (setq pos (vl-string-search del str)) (cons (substr str 1 pos) (LM:str->lst (substr str (+ pos 1 (strlen del))) del)) (list str) ) ) ;;----------------------------------------------------------------------;; (vl-load-com) (princ (strcat "\n:: Text2Table.lsp | Version 1.1 | \\U+00A9 Lee Mac " (menucmd "m=$(edtime,0,yyyy)") "\n:: Type \"txt2tab\" to Invoke ::" ) ) (princ) Quote
BIGAL Posted March 17, 2024 Posted March 17, 2024 (edited) (rtos num 2 3) is what your after, look at (vla-settext obj i j val), you may have to do each column separately as 1st column is 1, 2, 3 etc (rtos num 2 0) Edited March 17, 2024 by BIGAL Quote
