gsc Posted March 18, 2024 Posted March 18, 2024 Hi, I have a list (tmp_list1) that may contains at least 1 or more of the following strings: 00-Structure Safety Zone-temp 01-Create IAC-Safety Zones-temp 02-Create Scour Protections-temp 03-Create Archaeological Areas-temp 04-Create Maintenance Zones-temp 05-Create Seabed Steep Slope Areas-temp 06-Create Rock Steep Slope Areas-temp 07-Create Sediment Thickness-temp With a foreach function I want to compare per string, 1 by 1 whether the string equals 1 of the 3 expressions in the condition However, for the 2nd and 3rd expressions, the value of the string must equal 1 of those (3 or 4) possibilities. I thought I could achieve this with the OR function, but this apparently does not work. What am I doing wrong here? (foreach itm tmp_lst1 (cond ((equal (car itm) "00-Structure Safety Zone-temp") (print (strcat "this is " (car itm))) ) ((or (equal (car itm) "01-Create IAC-Safety Zones-temp") (equal (car itm) "02-Create Scour Protections-temp") (equal (car itm) "03-Create Archaeological Areas-temp") (equal (car itm) "04-Create Maintenance Zones-temp") ) (print (strcat "this is " (car itm))) ) ((or (equal (car itm) "05-Create Seabed Steep Slope Areas-temp") (equal (car itm) "06-Create Rock Steep Slope Areas-temp") (equal (car itm) "07-Create Sediment Thickness-temp") ) (print (strcat "this is " (car itm))) ) ) ;end cond ) ;end foreach Quote
rlx Posted March 18, 2024 Posted March 18, 2024 maybe : (defun t1 ( / tmp-lst ) (setq tmp_lst1 '("00-Structure Safety Zone-temp" "01-Create IAC-Safety Zones-temp" "02-Create Scour Protections-temp" "03-Create Archaeological Areas-temp" "04-Create Maintenance Zones-temp" "05-Create Seabed Steep Slope Areas-temp" "06-Create Rock Steep Slope Areas-temp" "07-Create Sediment Thickness-temp")) (foreach itm tmp_lst1 (cond ((equal itm "00-Structure Safety Zone-temp") (print (strcat "this is " itm))) ((member itm '("01-Create IAC-Safety Zones-temp" "02-Create Scour Protections-temp" "03-Create Archaeological Areas-temp" "04-Create Maintenance Zones-temp")) (print (strcat "this is " itm))) ((member itm '("05-Create Seabed Steep Slope Areas-temp" "06-Create Rock Steep Slope Areas-temp" "07-Create Sediment Thickness-temp")) (print (strcat "this is " itm))) ) ) ) You keep comparing (car itm) for every member in list... Quote
gsc Posted March 19, 2024 Author Posted March 19, 2024 Thanx, your'e right, this works more efficient Quote
