Steven P Posted March 19, 2024 Posted March 19, 2024 Does anyone know if it is possible to entmake a field text? Cheers (working on a little function to create blocks... all done with entmakes and was wanting to look at the borders and title blocks next... which have a field.. but I can't work that one out. The function works via the command line, single word to insert a block, quicker than 'insert' skipping the dialogue box, entmakes because that's how I am doing it.) Quote
tombu Posted March 19, 2024 Posted March 19, 2024 Keep in mind a field is linked to an object in a drawing. You have to insert the block first then create the field for it. If you make copies of that block and the field all those fields will reference the original insertion not the copied insertions. If you copy an object with field to another drawing the field will no longer work because the reference has to be set up in the current drawing. Plenty of useful code out there for labeling blocks using fields just keep in mind they are limited by being directly linked to a specific object in a specific drawing. http://www.cadtutor.net/forum/showthread.php?51254-Block-s-name-to-FIELD-(based-on-existing-lisp)&p=347968&viewfull=1#post347968 1 1 Quote
Tsuky Posted March 19, 2024 Posted March 19, 2024 It's entirely possible. You simply need to retrieve the ID of the object concerned. You can rely on the text provided in the dialog box when designing the field in manual mode, you just have to be careful to double the "\" character in the lisp code so that it is correctly interpreted. In lisp we can even have characteristics not accessible in a dialog box, an example of code to have the volume of a 3D solid (impossible to have this property in a dialog box) (vl-load-com) (defun c:Label_Volume ( / js htx AcDoc Space n obj ename pt alpha nw_obj) (princ "\nSelect solid.") (while (null (setq js (ssget (list '(0 . "3DSOLID") (cons 67 (if (eq (getvar "CVPORT") 1) 1 0)) (cons 410 (if (eq (getvar "CVPORT") 1) (getvar "CTAB") "Model")) ) ) ) ) (princ "\nAren't solid!") ) (initget 6) (setq htx (getdist (getvar "VIEWCTR") (strcat "\nGive the height of the text <" (rtos (getvar "TEXTSIZE")) ">: "))) (if htx (setvar "TEXTSIZE" htx)) (setq AcDoc (vla-get-ActiveDocument (vlax-get-acad-object)) Space (if (= 1 (getvar "CVPORT")) (vla-get-PaperSpace AcDoc) (vla-get-ModelSpace AcDoc) ) ) (vla-startundomark AcDoc) (repeat (setq n (sslength js)) (setq obj (ssname js (setq n (1- n))) ename (vlax-ename->vla-object obj) ) (initget 1) (redraw obj 3) (setq pt (getpoint "\nInsertion point?: ") alpha 0.0 nw_obj (vla-addMtext Space (vlax-3d-point pt) 0.0 (strcat "{\\fArial|b0|i0|c0|p34;" "%<\\AcObjProp.16.2 Object(%<\\_ObjId " (itoa (vla-get-ObjectID ename)) ">%).Volume \\f \"%lu2%pr2%ps[V=,m³]\">%" ) ) ) (redraw obj 4) (mapcar '(lambda (pr val) (vlax-put nw_obj pr val) ) (list 'AttachmentPoint 'Height 'DrawingDirection 'InsertionPoint 'Layer 'Rotation) (list 5 (getvar "TEXTSIZE") 5 pt (getvar "CLAYER") alpha) ) ) (vla-endundomark AcDoc) (prin1) ) 1 Quote
Steven P Posted March 19, 2024 Author Posted March 19, 2024 Nice, thanks..... So essentially create the text but include the codes in there - that will work From the examples above these are the important lines? I'll have a play with this later (strcat "%<\\AcObjProp Object(%<\\_ObjId " (itoa (vla-get-Objectid obj)) ">%).EffectiveName>%" ) (strcat " "%<\\AcObjProp.16.2 Object(%<\\_ObjId " (itoa (vla-get-ObjectID ename))">%).Volume>%" ) Quote
tombu Posted March 19, 2024 Posted March 19, 2024 I have a handful of drawings that contain a lot of blocks in them arranged to where I can examine them and added a modified version of Lee's code to quickly label the names of each of them with a field and group the field to the block so they select together for moving them around together. When inserting one of the blocks into another drawing I use the newer -INSERTCONTENT (Command) usually in macros for blocks we often import and since groups don't import the group names do not come in. Didn't like AutoCAD's major changes to the INSERT Command but the new command makes up for it. Examples: ^C^Cadcnavigate G:/ENGDESGN/BeaufordT/Blocks/Typicals/Typicals.dwg; that open them in Design Center which displays the blocks with names making them easy to insert or update. ^C^C-INSERTCONTENT G:/ENGDESGN/BeaufordT/Blocks/Typicals/Typicals.dwg;Modified F Curb; that inserts the block "Modified F Curb" from the drawing "G:/ENGDESGN/BeaufordT/Blocks/Typicals/Typicals.dwg". Easy-peasy with no coding required. Quote
BIGAL Posted March 20, 2024 Posted March 20, 2024 (edited) "single word to insert a block" -Insert use it in a lisp. Another B22 inserts block with a link to name "22" say in a list. I have a reactor code that lets you type say Bz, B22 etc it will remove the B but keep what is after and use that in a defun which may be a -insert defun. No Dcl. I have posted this before, you could do a Bxx.There is say 26 different versions available. I have Offset Circle Fillet in one version. fillet reactor.lsp Edited March 20, 2024 by BIGAL 1 Quote
Steven P Posted March 20, 2024 Author Posted March 20, 2024 (edited) I've never looked at reactors really, but could be a thing to look at one day. This is my current amusement, more visual than remembering all the block names - I think you have posted similar before (a few times). Edited March 20, 2024 by Steven P Quote
BIGAL Posted March 20, 2024 Posted March 20, 2024 Thats an image out of a pop menu, nice thing is when screen is full it supports next so a full screen again. Select image or text. Best is that you can use Notepad to make, the images are slides but I made like a 100 in one go. Quote
Steven P Posted March 21, 2024 Author Posted March 21, 2024 Yes, that the image of the one I made up - very similar layout to the rest though, it is all working, just got to populate the menus now. (doing it for my amusement and to help my memory with block names, thinking I'll make pseudo tabs for fun (Electrical, Civil, Mechanical, Drawing Utilities and so on)) Quote
Steven P Posted May 1, 2024 Author Posted May 1, 2024 Coming back to this one again - got distracted and diverted along a couple of other paths but now back on target to make fields in title blocks. The ones I am looking to add are drawing filepath, save date and saved by. This all links back to the DCL ideas above which were the distractions - single word block entries with no more user interface except select insert point. So I have this: (setq FieldText (entmakex (list '(0 . "MTEXT") '(100 . "AcDbEntity") '(8 . "0") '(100 . "AcDbMText") '(10 1934.27 1124.51 0.0) '(40 . 2.5) (cons 1 "%<\\AcVar Filename \\f \"%tc4%fn7\">% %<\\AcVar SaveDate \\f \"MMMM d, yyyy - hh:mm tt\">% %<\\AcVar LastSavedBy \\f \"%tc4\">%") '(7 . "Standard") '(11 1.0 0.0 0.0) ))) ; end setq, entmakex, list Which results in this on the screen: Double click on that and the filepath, date and last saved by are updated. However only does that when double clicking on the text string. Things like redraw, regen, updatefield, save-close-open aren't updating this... so what do I need to do next or do I need to use a different function for fields as opposed to entmake? (all the lines, arcs, attributes and so on are all entmakes) Suspect I have to create a Acad_XDictionary - but never done anything with them before (dxf codes 102, and 360 for the dictinary, entmake doesn't like that for me just now) Thanks for any more help, Quote
BIGAL Posted May 2, 2024 Posted May 2, 2024 The issue maybe is that you have 2 variables Savedate and Lastsavedby when you close the dwg these will probably disappear, so no update, I have started using this for saving info in a dwg, rather than variables 1-5, Userr1, Useri1, Users1. (vlax-ldata-put "StevenP" "SAVEDATE" yourdate ) (setq savedate (vlax-ldata-get "StevenP" "SAVEDATE")) 1 Quote
Tsuky Posted May 2, 2024 Posted May 2, 2024 14 hours ago, Steven P said: Double click on that and the filepath, date and last saved by are updated. However only does that when double clicking on the text string. Things like redraw, regen, updatefield, save-close-open aren't updating this... so what do I need to do next or do I need to use a different function for fields as opposed to entmake? (all the lines, arcs, attributes and so on are all entmakes) Suspect I have to create a Acad_XDictionary - but never done anything with them before (dxf codes 102, and 360 for the dictinary, entmake doesn't like that for me just now) Thanks for any more help, Indeed (entmake) does not work entirely with fields. And you're right about dictionaries, we can do them with entmake, but it's complicated. With (vla-addMtext), it's much simpler, it takes care of the dictionary itself. ((lambda ( / AcDoc Space) (setq AcDoc (vla-get-ActiveDocument (vlax-get-acad-object)) Space (if (= 1 (getvar "CVPORT")) (vla-get-PaperSpace AcDoc) (vla-get-ModelSpace AcDoc) ) ) (initget 1) (vla-update (vla-addMtext Space (vlax-3d-point (getpoint "\nInsertion point; ")) 0.0 "%<\\AcVar Filename \\f \"%tc4%fn7\">% %<\\AcVar SaveDate \\f \"MMMM d, yyyy - hh:mm tt\">% %<\\AcVar LastSavedBy \\f \"%tc4\">%" ) ) )) 2 Quote
tombu Posted May 2, 2024 Posted May 2, 2024 I added drawing file path, save date and saved by to custom properties in my template files placing them in all our title blocks so they're displayed on every layout on all our drawings automatically. I added drop-downs in Properties tab for setting custom properties like picking the engineer for the signature block or entering the field book number for the survey notes. 1 Quote
Steven P Posted May 2, 2024 Author Posted May 2, 2024 Thanks, This is one of those exercises "can I do it" rather than a need to do it - we have the templates etc created, saved away and working OK - but I wanted to see what I can create purely from LISP. Lines and so on are easy enough, but I am getting to the last few complicated pieces now. Big Al, you've given me an idea for something else there.... thanks.... that is another day of "I wonder if this can work". Tsuky, that looks like what I was thinking I'd have to do, thanks, I'll give it a go. Quote
BIGAL Posted May 4, 2024 Posted May 4, 2024 Like tombu had signature block insert into all layouts etc .Paper copy was signed legal requirement. 2 Quote
Steven P Posted August 3 Author Posted August 3 Coming back to this one again... On 5/2/2024 at 3:49 AM, Tsuky said: Indeed (entmake) does not work entirely with fields. And you're right about dictionaries, we can do them with entmake, but it's complicated. With (vla-addMtext), it's much simpler, it takes care of the dictionary itself. I came on this solution, weekend testing and it works so far. Just needs the vla-put-textstring to update the text to a field. Not checked yet if it will do a nice mix of text and field - should do. Also noted that can entmake text with a field embedded into a block - doesn't need that extra line, when block is inserted it does its stuff (example, attributes for drawing number and drawing number repeated at the top left corner as a field.. see next comment) (setq MyString -String including field codes- ) (setq MTextObj (vlax-ename->vla-object (entmakex (list '(0 . "MTEXT") '(100 . "AcDbEntity") '(67 . 0) '(8 . "0") '(100 . "AcDbMText") '(10 0.0 0.0 0.0) '(40 . 2.5) '(41 . 0.0) '(46 . 0.0) '(71 . 1) '(72 . 5) (cons 1 MyString) '(7 . "Standard") '(11 1.0 0.0 0.0) '(42 . 15.4246) '(43 . 2.58697) '(50 . 0.0) '(73 . 1) '(44 . 1.0) )) ; end entmakex ; end list )) ; end vlax-ename ; end setq (vla-put-textstring MTextObj MyString) ;; update field. Quote
Steven P Posted August 3 Author Posted August 3 (edited) Part 2 of my weekend homework, adding more for info. This one searches for blocks, gets the object ID for a named attribute and returns the field expression for that attribute. MyString is a default text if the required attribute isn't found in any blocks (loop stops when it finds the named attribute in a block). Example I was looking at is as my Insert blocks DCL, above, adding in a drawing border made of a few blocks one of them is a field from the drawing number - adding in the title block the object name is dynamic, this gets the code needed for that title block (defun PMField ( MyField MyString / MyBlocks Ent acount Att x tmplist) (setq MyBlocks (ssget "_X" '((0 . "INSERT")))) (setq acount 0) (while (and (equal tmplist nil) (< acount (sslength MyBlocks))) (setq Ent (ssname MyBlocks acount)) (foreach Att (vlax-invoke (vlax-ename->vla-object Ent) 'GetAttributes ) ;_ end of vlax-invoke (if (= (strcase (vla-get-TagString Att)) MyField) (setq tmpList (cons Att (vla-get-TextString Att))) ) ; end if ) ; end foreach (setq acount (+ acount 1)) ) ; end while (if (equal tmplist nil) (progn (princ (strcat "No block with attribute '" MyField "' found")) ;; (setq MyString "OFFICIAL") ) (progn (setq x (car tmplist)) (setq MyString (strcat "%<\\AcObjProp Object(%<\\_ObjId "(itoa (vla-get-objectid x))">%).TextString>%")) ) ; end progn ) ; end if MyString ) Edited August 3 by Steven P Quote
BIGAL Posted August 3 Posted August 3 (edited) Have a look at Lee-mac "page X of Y" does just that for title blocks. You can make a field that uses taborder for sheet number and count for the total of layouts., I would use these in attributes of a title block where I worked it had 25 attributes. Trying to find a shorter version. Had something the COUNT did not work in Bricscad V24. Just a second comment look here for DWGINDEX.lsp does just that makes a index of your layouts based on title block Tag names. InsertSheetofSheets.lsp Dwgindex.lsp Edited August 3 by BIGAL 1 Quote
Steven P Posted August 4 Author Posted August 4 Weirdly for this one, I didn't check Lee Mac, I usually do. I did look at Taborder, but likely that the title blocks will be updated in the near future, tab order might change so this way was a bit future proofing (fewer later changes). Thanks for LISPs, I'll take a look at them this morning Quote
