Hi, I have this code to Save Text into a MS Word File. I use Libre office now and the code don't work because try to find MS Office. I change the follow lines in the code but is not working ,gives me this message. Can any one help ?
Can't create Word document. Microsoft Office must be installed
   (if (not (setq Word (vlax-get-object "Libre.Application")));;;is already open ?
    (setq Word (vlax-get-or-create-object "Libre.Application"));;; no open
;;; CADALYST 08/05	Tip 2053: SaveDoc.lsp	Text into a MS Word File (c) Andrzej Gumula
;;; This routine exports selected text to Word document
;;; Microsoft Office must be installed in Windows
;;; Andrzej Gumula
;;; ul. Modrzewiowa 19/54
;;; 40-171 Katowice POLAND
;;; email: a.gumula@wp.pl
(defun c:Save2Doc (/ TxtSet Word Docs NewDoc Paragraphs Range
                    OldTxtList NewTxt IdTxtList FontName Txt Count
		    Flag#1 Flag#2)
(defun Dxf (Index)
 (cdr (assoc Index (entget (ssname TxtSet Count))))
);end Dxf
(defun ClearMTFormat (Str / Item TLength Char New);;; clear mtext format in string
  (setq Item 1 TLength (strlen Str) New "")
  (while (<= Item TLength)
   (setq Char (substr Str Item 1))
   (if	(= Char "\\")
      (setq Item (1+ Item))
      (cond
       ((member Char '("\\" "f" "F" "C" "H" "S" "T" "Q" "W"))
        (while (and (/= Char ";") (<= Item TLength))
        );end while
       ((= Char "P")
        (setq New (strcat New "\n"))
       ((member Char '("{" "}"))
	(setq New (strcat New Char))
      );end cond
     );end progn
     (if (not (member Char '("{" "}")))
     );end if
    );end if
   );end while
   (cond (New) (T ""))
);end ClearMTFormat
(defun GetOpenDocs (Docs / Item Names);;; list of open Word documents
  (repeat (setq Item (vla-get-count Docs))
   (setq Names (cons (strcase (findfile (vla-get-fullname (vla-item Docs Item)))) Names))
   (setq Item (1- Item))
  );end repeat
  Names
);end GetOpenDocs
(princ "\nSelect TEXT (MTEXT) to export to Word document: ")
(cond
 ((setq TxtSet (ssget '((0 . "*TEXT"))))
  (cond
  ((setq File (getfiled "Select Word document" (strcat (vl-filename-base (getvar "dwgname")) ".doc") "doc" 1))
   (vl-load-com)
   (prompt "\nExport text to Word. Please wait...")
   (if (not (setq Word (vlax-get-object "Word.Application")));;;is already open ?
    (setq Word (vlax-get-or-create-object "Word.Application"));;; no open
    (setq Flag#1 T)
   );end if
   (cond
    (Word
    (if (not Flag#1) (vla-put-visible Word :vlax-false));;; hide window application
    (if (findfile File)
     (setq Flag#2 (member (strcase (findfile File)) (GetOpenDocs (vlax-get-property Word 'Documents)))
	   NewDoc (vlax-invoke-method (vlax-get-property Word 'Documents) 'Open File))
     (setq  NewDoc (vlax-invoke-method (vla-get-documents Word) 'add))
    );end if
    (setq Paragraphs (vlax-get-property NewDoc 'Paragraphs) Count 0)
    (repeat (sslength TxtSet)
     (setq String (vla-get-TextString (vlax-ename->vla-object (ssname TxtSet Count))))
     (setq Range (vlax-get-property (vlax-get-property Paragraphs 'last) 'Range))
     (if (not (setq FontName (cdar (cdadr (assoc -3 (entget (tblobjname "STYLE" (Dxf 7)) '("ACAD")))))))
      (setq FontName (vl-filename-base (cdr (assoc 3 (tblsearch "STYLE" (Dxf 7))))))
     );end if
     (vlax-put-property (vlax-get-property Range 'Font) 'Name FontName)
     (if (= (Dxf 0) "MTEXT") (setq String (ClearMTFormat String)))
     (vlax-invoke-method Range 'InsertAfter (strcat String "\n"))
     (setq Count (1+ Count))
    );end repeat
    (if (vl-catch-all-error-p (vl-catch-all-apply 'vla-saveas (list NewDoc File)))
      (prompt "\nProbably selected file is read-only. Cannot export text to this file. ")
      (vla-saveas NewDoc File);;; save document
    );end if
    (cond
     ((not Flag#1)
      (vla-quit Word 0)
     (T (if (not Flag#2) (vla-close NewDoc));;; close application
        (vla-put-visible Word :vlax-true);;; show application
    );end cond
    (mapcar 'vlax-release-object (list Word NewDoc Paragraphs Range));;; objects release
    (mapcar '(lambda (x) (set x nil)) '(Word NewDoc Paragraphs Range));;; null all variables
   (T (prompt "\nCan't create Word document. Microsoft Office must be installed. "))
  );end cond Word
  (T (prompt "\nFile no selected. "))
 );end cond
 (T (prompt "\nNothing selected. "));;; text no selected
);end cond
);end c:Save2Doc
(defun c:SD ()
  (c:Save2Doc)
);end c:SD
(prompt "\nLoaded new command Save2Doc [SD]. ")
(prompt "\n[c]2004 Andrzej Gumula. ")
;************** in the future - maybe in next version ?
;(vlax-invoke-method Range 'InsertSymbol 176 nil)   ;degree%%d
;(vlax-invoke-method Range 'InsertSymbol 177 nil t) ;plus-minus%%p
;(vlax-invoke-method Range 'InsertSymbol 216 nil t) ;diameter%%c
Thanks
To talk to libre office is very different to Excel & Word Microsoft products. This is the start.
(setq oServiceManager (vlax-get-or-create-object "com.sun.star.ServiceManager"))
I have started to look at Libre making some functions similar to my Excel functions. It has a bit of a low priority unfortunately. There is code out there most of it is in VBA which is OK.
Here is a lot of word functions do apologise as no Author name. Could use that as a start for more functionality.
Just Google it is a long search start by joining Libre Office forums can look for stuff there.
It may be easier to go other way open libre and run a macro that reads text. have a look at the Excel macros.
write text to word.lsp draw object xl acad.xlsm
Like SLW210 the syntax calls to Libre are very different to Excel / Word so it takes time googling to find the correct answers. I have write to a cell in Libre Calc but that is as far as I have gone.
This will open an existing Libre odt file. Could be blank like a dwt.
(setq filename "d:\\acadtemp\\Test 1.odt")
    (not
	(setq
	  oDesktop (vl-catch-all-apply
		     'vlax-invoke-method
		     (list oServiceManager 'createInstance "com.sun.star.frame.Desktop")
    (not
	(setq
	  oCalcDoc (vl-catch-all-apply
		     'vlax-invoke-method
		     (list oDesktop
			   'loadComponentFromURL
			   (strcat "file:///" (vl-string-translate "\\" "/" FileName))
			   "_blank"
			   0
			   (vlax-make-safearray vlax-vbObject (cons 0 0))
End of story for now, no idea how to write lines of text.
Edited by BIGAL
