skipsophrenic Posted March 5, 2009 Posted March 5, 2009 Has anyon ever experienced this problem? I've been working on a drawing, and now for some obscure reason, nothing is showing in the "Drawing" area. All toolbars accounted for. All servicepacks installed. I havent deleted the lot (Checked Command History) All I've got is blackness. Quote
ReMark Posted March 5, 2009 Posted March 5, 2009 Turn on the lights, take off the sunglasses and open your eyes. You're sitting in front of the wrong monitor. Go back to YOUR desk. And you tried a 'zoom extents' and nothing appeared? Quote
skipsophrenic Posted March 5, 2009 Author Posted March 5, 2009 Turn on the lights, take off the sunglasses and open your eyes. You're sitting in front of the wrong monitor. Go back to YOUR desk. :lol: And you tried a 'zoom extents' and nothing appeared? Tried and failed Quote
ReMark Posted March 5, 2009 Posted March 5, 2009 And you checked Layer Manager and all layers are "on"? Is someone in your office having a little fun at your expense? Who did you p*** off yesterday? Quote
NBC Posted March 5, 2009 Posted March 5, 2009 I've had this a few times. It's usually something to do with graphics card issues; or even drawings received from (insert expletive) Architects Quote
skipsophrenic Posted March 5, 2009 Author Posted March 5, 2009 And you checked Layer Manager and all layers are "on"? Yep Is someone in your office having a little fun at your expense? Who did you p*** off yesterday? No one as far as am aware, Odd thing when i closed ACAD an reopened it everything was there Quote
skipsophrenic Posted March 5, 2009 Author Posted March 5, 2009 I've had this a few times. It's usually something to do with graphics card issues; or even drawings received from (insert expletive) Architects Know what u mean! LOL, but this is my own dwg. very odd - never happened b4 Quote
ReMark Posted March 5, 2009 Posted March 5, 2009 Did you create a wipeout (with frame turned off) and place it over part (or the entire) drawing? Sort of a "play a stupid trick on myself" thing and forget you did it? Quote
skipsophrenic Posted March 5, 2009 Author Posted March 5, 2009 No wipeout and i have NO idea. here's what the command histor was before i closed ACAD Command: *Cancel* Command: *Cancel* Command: <Rename layout> Command: *Cancel* Command: *Cancel* Command: <Rename layout> Command: *Cancel* Command: *Cancel* Command: <Rename layout> Command: *Cancel* Command: *Cancel* Command: <Rename layout> Command: *Cancel* Command: *Cancel* Command: <Rename layout> Command: *Cancel* Command: *Cancel* Command: <Switching to: RCDL-DRG-002 (2)> Regenerating layout. Regenerating model - caching viewports. Command: *Cancel* Command: *Cancel* Command: <Rename layout> Command: *Cancel* Command: *Cancel* Command: <Rename layout> Command: Specify opposite corner: Command: Specify opposite corner: *Cancel* Command: _.MSPACE Command: _.PSPACE Command: Command: ** STRETCH ** Specify stretch point or [base point/Copy/Undo/eXit]: Command: *Cancel* Command: *Cancel* Command: <Switching to: RCDL-DRG-001> Regenerating layout. Regenerating model - caching viewports. Command: *Cancel* Command: *Cancel* Command: <Switching to: Model> Regenerating model - caching viewports. Command: Command: e ERASE 1 found Command: '_.zoom _e Command: *Cancel* Automatic save to C:\DOCUME~1\psmith2\LOCALS~1\Temp\001dwg_1_1_4475.sv$ ... Command: Command: *Cancel* Command: <Switching to: RCDL-DRG-001> Regenerating layout. Regenerating model - caching viewports. Command: Specify opposite corner: Command: Command: Command: _move 2 found Specify base point or [Displacement] <Displacement>: Specify second point or <use first point as displacement>: Command: Command: Command: Command: _mtedit Command: *Cancel* Command: *Cancel* Command: <Switching to: RCDL-DRG-002> Regenerating layout. Regenerating model - caching viewports. Command: *Cancel* Command: *Cancel* Command: <Switching to: RCDL-DRG-003> Regenerating layout. Regenerating model - caching viewports. Command: *Cancel* Command: *Cancel* Command: <Switching to: RCDL-DRG-002> Regenerating layout. Regenerating model - caching viewports. Command: *Cancel* Command: *Cancel* Command: <Switching to: RCDL-DRG-003> Regenerating layout. Regenerating model - caching viewports. Command: *Cancel* Command: *Cancel* Command: <Switching to: RCDL-DRG-004> Regenerating layout. Regenerating model - caching viewports. Command: Command: e ERASE 1 found Command: *Cancel* Command: *Cancel* Command: <Switching to: RCDL-DRG-002> Regenerating layout. Regenerating model - caching viewports. Command: *Cancel* Command: *Cancel* Command: <Switching to: RCDL-DRG-004> Regenerating layout. Regenerating model - caching viewports. Command: Command: Command: Command: _copybase Specify base point: 1 found Command: *Cancel* Command: *Cancel* Command: <Switching to: RCDL-DRG-002> Regenerating layout. Regenerating model - caching viewports. Command: Command: Command: _pasteclip Duplicate definition of block Schedule-Rev-Txt ignored. Duplicate definition of block Schedule-Title-Txt ignored. Duplicate definition of block BAR SCHEDULE ignored. Specify insertion point: Command: *Cancel* Command: *Cancel* Command: <Switching to: RCDL-DRG-001> Regenerating layout. Command: Command: Command: Command: _mtedit Regenerating model. Command: Specify opposite corner: Command: re REGEN Regenerating layout. Command: Regenerating model. re REGEN Regenerating layout. Command: _u REGEN Command: _u INTELLIZOOM INTELLIZOOM Command: _u Command: _u REGEN Command: _u MTEDIT GROUP Command: _u LAYOUT_CONTROL Regenerating layout. Regenerating model - caching viewports. Command: _u PASTECLIP GROUP Command: *Cancel* Command: *Cancel* Command: <Switching to: RCDL-DRG-003> Regenerating layout. Regenerating model - caching viewports. Command: *Cancel* Command: *Cancel* Command: <Switching to: RCDL-DRG-001> Regenerating layout. Command: *Cancel* Command: *Cancel* Command: <Switching to: RCDL-DRG-002> Regenerating layout. Regenerating model - caching viewports. Command: Specify opposite corner: Command: Specify opposite corner: Command: Specify opposite corner: Command: *Cancel* Command: *Cancel* Command: *Cancel* Command: *Cancel* Command: *Cancel* Command: *Cancel* Command: *Cancel* Command: *Cancel* Command: <Switching to: Model> Regenerating model - caching viewports. Command: Command: Command: _line Specify first point: Specify next point or [undo]: Specify next point or [undo]: Automatic save to C:\DOCUME~1\psmith2\LOCALS~1\Temp\001dwg_1_1_4475.sv$ ... Command: Command: Specify opposite corner: Command: Command: Command: _line Specify first point: Specify next point or [undo]: Specify next point or [undo]: Specify next point or [Close/Undo]: Specify next point or [Close/Undo]: Specify next point or [Close/Undo]: Specify next point or [Close/Undo]: Specify next point or [Close/Undo]: Specify next point or [Close/Undo]: Command: Specify opposite corner: Command: *Cancel* Command: *Cancel* Command: '_.zoom _e Command: Command: Specify opposite corner: Command: Specify opposite corner: Command: Specify opposite corner: Command: e ERASE 542 found Dimension disassociated. Dimension disassociated. Dimension disassociated. Dimension disassociated. Dimension disassociated. Dimension disassociated. Dimension disassociated. Dimension disassociated. Dimension disassociated. Dimension disassociated. Dimension disassociated. Dimension disassociated. Dimension disassociated. Command: '_.zoom _e Command: _u ZOOM INTELLIPAN Command: _u ERASE Command: Command: ** STRETCH ** Specify stretch point or [base point/Copy/Undo/eXit]: Command: ** STRETCH ** Specify stretch point or [base point/Copy/Undo/eXit]: Command: ** STRETCH ** Specify stretch point or [base point/Copy/Undo/eXit]: Command: e ERASE 1 found Command: Specify opposite corner: Command: e ERASE 7 found Command: '_.zoom _e Command: Command: *Cancel* Command: *Cancel* Command: *Cancel* Command: <Switching to: RCDL-DRG-001> Regenerating layout. Command: '_.zoom _e Command: *Cancel* Command: *Cancel* Command: <Switching to: RCDL-DRG-002> Regenerating layout. Regenerating model - caching viewports. Command: Automatic save to C:\DOCUME~1\psmith2\LOCALS~1\Temp\001dwg_1_1_4475.sv$ ... Command: Command: *Cancel* Command: *Cancel* Command: <Switching to: RCDL-DRG-003> Regenerating layout. Regenerating model - caching viewports. Command: *Cancel* Command: *Cancel* Command: <Switching to: RCDL-DRG-004> Regenerating layout. Regenerating model - caching viewports. Command: Automatic save to C:\DOCUME~1\psmith2\LOCALS~1\Temp\001dwg_1_1_4475.sv$ ... Command: Command: repair Unknown command "REPAIR". Press F1 for help. Command: audit Fix any errors detected? [Yes/No] <N>: y Auditing Header Auditing Tables Auditing Entities Pass 1 Pass 1 500 objects auditedAcDbSortentsTable(26784) Error for Entry (28C06,28C09) eDuplicateKey fixed Pass 1 7100 objects audited Auditing Entities Pass 2 Pass 2 7100 objects audited Auditing Blocks 153 Blocks audited Total errors found 1 fixed 1 Erased 0 objects Command: Command: Command: _qsave Quote
ReMark Posted March 5, 2009 Posted March 5, 2009 Well? What's the story? Problem resolved or are you still staring into a black hole? Quote
skipsophrenic Posted March 6, 2009 Author Posted March 6, 2009 Resolved on its own - Somehow?? Don't ask me how as I've got NO idea Quote
ReMark Posted March 6, 2009 Posted March 6, 2009 Maybe you shouldn't do drugs so early in the morning. Quote
rkent Posted March 7, 2009 Posted March 7, 2009 Has anyon ever experienced this problem? I've been working on a drawing, and now for some obscure reason, nothing is showing in the "Drawing" area. All toolbars accounted for. All servicepacks installed. I havent deleted the lot (Checked Command History) All I've got is blackness. I have it happen to me, and only on drawings where I have used TTF. If I change the TTF to shx I never see the problem again. Others have said turning hardware acceleration off will fix it. Quote
