Please Can Someone Answer This Simple Question.
I Have A Circle, Is There A Command To Insert Text Into Centre Of That Circle.
I Can Do Enclose Text But Not The Above.
Thanks
Is it text or mtext? Can you not justify using properties then move with the handle to snap to the centre?:?
Use single line text
Justify Middle Center (MC)
Then you just use object snap to the center of your circle and follow the rest of the command prompts.
when you start the command for text, first you type J (justify) and chosse MC (middle center) then you choose as insert point the center of your circle and you follow the prompts
Guest Alan Cullen
You can set the justification to "middle" when you start the DTEXT command. Unfortunately, if you have multiline dtext, then only the top line of text will be centred with the circle centre. You would manually have to move all the multiline dtext to the centre of the circle.
  • 3 years later...
