Guest paulblackwell Posted September 28, 2004 Share Posted September 28, 2004 Hello, I'm not too sure where this question sits in the forum? I need to retreive data from an Oracle database and display it on a AutoCAD drawing. For example, a floor plan with desk references needs to display the persons name sitting at the desk, read from the database. I don't necessarily need the drawing updatated real time, an overnight process would be fine. It would be a great help if someone could point me in the right direction, software packages, programming languages, anything? Thanks in adavnce, Paul Quote Link to comment Share on other sites More sharing options...
fuccaro Posted September 30, 2004 Share Posted September 30, 2004 When using AutoCAD 2k I played with the DBCONNECT command. I managed to link the records stored in a DBF file to lines placed in a drawing. AutoCAD can label your desks with names stored in a database. You "just" need to connect the drawing to the Oracle file, create the links between the AutoCAD entities and the records and to define a label template. I used this only once for testing Quote Link to comment Share on other sites More sharing options...
hendie Posted September 30, 2004 Share Posted September 30, 2004 hi fuccaro, nice to see you back, even if only for a brief visit. Paul, it's possible and not too difficult. I would recommend using VBA for this. It is possible also in Lisp but much more difficult. I've never used Oracle but I use an MS Access database on a daily basis. I use VBA to connect to the database, query it with SQL and retrieve data which is automatically inserted into the drawing, using block attributes. Personally I found the dbconnect feature of autocad too limiting and avoided it altogether. the biggest problem I found was getting the connection string correct, once that was done the rest was relatively easy. Quote Link to comment Share on other sites More sharing options...
Mica Posted March 7, 2012 Share Posted March 7, 2012 Hello, I am also interested in this topic. I know to use db connect for exporting from database to CAD, but I would like to work in two ways, also when I change something on .dwg to see changes in my oracle database. I also want to know how can I with double click (or something similar) on my blocks import table so I can see it. It would be helpfull if someone can share with me knowlage about this. Best regards, Milan Quote Link to comment Share on other sites More sharing options...
