leonucadomi Posted April 8, 2024 Posted April 8, 2024 hello: some routine to change all the lines of a drawing to thicknees 0? thanks Quote
marko_ribar Posted April 8, 2024 Posted April 8, 2024 (defun c:linesthickness-0 ( / s i e ex ) (prompt "\nSelect LINE entities...") (setq s (ssget "_:L" (list (cons 0 "LINE")))) (repeat (setq i (sslength s)) (setq e (ssname s (setq i (1- i)))) (if (assoc 39 (setq ex (entget e))) (entupd (cdr (assoc -1 (entmod (subst (cons 39 0.0) (assoc 39 ex) ex))))) ) ) (princ) ) 1 1 Quote
StevJ Posted April 9, 2024 Posted April 9, 2024 This one works well for me (DEFUN C:PLW0 (/ ss1) ;; Set PolyLine Width to 0.0 (setq ss1 (ssget ":L")) (command "_.PEDIT" "_M" ss1 "" "_W" 0.0 "") (princ) ) Steve 1 Quote
mhupp Posted April 9, 2024 Posted April 9, 2024 Autolisp way (defun C:PL0 (/ ss) ;; Set PolyLine Width to 0.0 (setq ss (ssget ":L")) (foreach poly (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex SS)))) (vla-put-lineweight poly 0) ) (princ) ) 1 Quote
pkenewell Posted April 9, 2024 Posted April 9, 2024 8 hours ago, mhupp said: Autolisp way (defun C:PL0 (/ ss) ;; Set PolyLine Width to 0.0 (setq ss (ssget ":L")) (foreach poly (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex SS)))) (vla-put-lineweight poly 0) ) (princ) ) For those who don't know the basics of Visual LISP: don't forget to add (vl-load-com) to the top of the routine. 1 Quote
