Nickvnlr Posted April 9, 2024 Posted April 9, 2024 I want to be able to make a selection of lines/polylines/etc and get a report of total length separated by lineweight. This is the LISP I have so far, but it just adds the length of all lines in the drawing and puts the results in the command prompt. I would like to insert the results as text. Any help is appreciated. Thank you! (defun c:SumLengthsByLineweight (/ _length ss e cur data) (setq _Length (lambda (en) (vlax-get en 'Length))) (if (setq ss (ssget "_X" '((0 . "LINE,POLYLINE,LWPOLYLINE")))) (progn (repeat (sslength ss) (setq e (vlax-ename->vla-object (ssname ss 0))) (if (setq cur (assoc (setq lyn (vla-get-LineWeight e)) data)) (setq data (subst (list (car cur) (+ (_Length e) (cadr cur))) cur data)) (setq data (cons (list lyn (_Length e)) data)) ) (ssdel (ssname ss 0) ss) ) (foreach itm data (print itm) (princ)) ) ) ) Quote
Nikon Posted April 9, 2024 Posted April 9, 2024 2 hours ago, Nickvnlr said: I would like to insert the results as text. https://lee-mac.com/lengthfield.html Length Field Upon issuing the command syntax LF (Length Field) at the AutoCAD command-line, the program first prompts the user to make a selection of objects for which to return the length summation. At this prompt, the user may select any number of Arcs, Circles, Lines, 2D Polylines (light or heavy), or 3D Polylines. Quote
Nickvnlr Posted April 9, 2024 Author Posted April 9, 2024 OK, but I want the results separated by lineweight. Quote
Nikon Posted April 9, 2024 Posted April 9, 2024 (edited) In this code, you can see how to insert text into a drawing: ;; inserting the sum of the length of linear objects into the drawing (defun c:LPLINE (/ e ss l p i) (if (setq l 0.0 ss (ssget '((0 . "LINE,SPLINE,LWPOLYLINE,POLYLINE,ARC,CIRCLE,ELLIPSE")))) (progn (repeat (setq i (sslength ss)) (setq e (ssname ss (setq i (1- i))) l (+ l (vlax-curve-getDistAtParam e (vlax-curve-getEndParam e))) ) ) (if (setq p (getpoint "\nSpecify a point to insert text: ")) (entmake (list '(0 . "TEXT") '(100 . "AcDbText") (cons 10 (trans p 1 0)) (cons 40 (/ 5)) (cons 1 (rtos l)) ) ) (princ (strcat "\nTotal length = " (rtos l))) ) ) ) (princ) ) quick selection by line weight, then this lisp... Edited April 9, 2024 by Nikon Quote
Nickvnlr Posted April 9, 2024 Author Posted April 9, 2024 I can't figure out how to get it to work with multiple lines/items. Quote
Jonathan Handojo Posted April 9, 2024 Posted April 9, 2024 A courtesy of mine to share what I use in my workplace. Sums by all general properties CurveTotal.LSP 1 Quote
Nickvnlr Posted April 9, 2024 Author Posted April 9, 2024 Thanks, but it gives me an error when trying to insert the table. Command: CRVTOTAL Select objects: Specify opposite corner: 27 found Select objects: Specify insertion point for table <exit>: Error: bad argument type: VLA-OBJECT nil I think there are functions not supported by LT. Quote
Jonathan Handojo Posted April 9, 2024 Posted April 9, 2024 Ah, that explains it. My apologies, LT does have major limitation. If summarising it into a table is not achievable, then perhaps you prefer a csv/txt export? Or just in the command line? Quote
Nickvnlr Posted April 9, 2024 Author Posted April 9, 2024 For now, perhaps a csv. I appreciate the effort. Quote
Jonathan Handojo Posted April 9, 2024 Posted April 9, 2024 This one will now export it to a CSV file. Type CRVTOTALCSV to run the command. CurveTotal_csv.LSP 1 Quote
Nickvnlr Posted April 9, 2024 Author Posted April 9, 2024 That works. Thank you! This gives me something to play with and tweak to get what I want. Quote
