Hi All,
I am trying to see if I can find someone who would know how to make a small modification to Lee Mac's Copy2Drawingsv1-3 lisp routine. The lisp itself works great and is fantastic, but i would find it a little more useful if it did not copy the layout as well but rather inserts it into all layouts in the drawing its copying to. Currently it copies the layout name and if it doesn't exist, creates it in the drawing.
Seems like a minor adjustment, however I'm a novice at writing lisp routines.
;;-----------------------=={ Copy to Drawings }==-----------------------;;
;;  This program enables the user to copy a selection of objects to a   ;;
;;  selected set of drawings, without opening the drawings in the       ;;
;;  AutoCAD Editor.                                                     ;;
;;  The program will first prompt the user to make a selection of       ;;
;;  objects residing in the active drawing layout that are to be        ;;
;;  copied. Following a valid selection, the user will be prompted via  ;;
;;  a dialog interface to compile a list of drawings (dwg/dwt/dws) to   ;;
;;  which the selected objects will be copied.                          ;;
;;  The program will then proceed to copy every object in the selection ;;
;;  to each selected drawing using an ObjectDBX interface.              ;;
;;  The program will retain all information associated with each        ;;
;;  copied object, including the position, scale, rotation, etc.        ;;
;;  Properties such as layers & linetypes will be imported if not       ;;
;;  already present in the external drawing. Similarly, the drawing     ;;
;;  layout in which the source objects reside will be created if not    ;;
;;  already present in the external drawing.                            ;;
;;  The program is compatible for use with all drawing objects          ;;
;;  (including XRefs & Dynamic Blocks) with the exception of Viewports. ;;
;;  After copying the set of objects to each drawing, the program will  ;;
;;  save the external drawing. Due to a restriction on the saveas       ;;
;;  method when invoked through an ObjectDBX interface, all drawings    ;;
;;  will be saved to the native format, i.e. the latest version         ;;
;;  available - this is unfortunately unavoidable.                      ;;
;;  Note that when saving drawings through ObjectDBX, drawing file      ;;
;;  thumbnails will be lost until the next manual save.                 ;;
;;  Author:  Lee Mac, Copyright © 2013  -  www.lee-mac.com              ;;
;;  Version 1.2    -    2013-05-17                                      ;;
;;  Version 1.3    -    2016-03-21                                      ;;
;;  - Updated Get Files Dialog function to fix filename sorting bug     ;;
;;    and incorrect enabling of 'Add Files' button when a directory is  ;;
;;    selected.                                                         ;;
;;  - Refined output message to report unsuccessful drawings.           ;;
(defun c:c2dwg ( / *error* _getitem acd app dbx doc dwl err inc lst msg sel tab var vrs )
    (defun *error* ( msg )
        (if (and (= 'vla-object (type dbx)) (not (vlax-object-released-p dbx)))
            (vlax-release-object dbx)
        (if (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*"))
    (defun _getitem ( col itm )
        (if (not (vl-catch-all-error-p (setq itm (vl-catch-all-apply 'vla-item (list col itm)))))
            itm
    (setq app (vlax-get-acad-object)
          acd (vla-get-activedocument app)
          tab (if (= 1 (getvar 'cvport)) (getvar 'ctab) "Model")
          cnt 0
    (cond
        (   (not
                (and
                    (setq sel (ssget (list '(0 . "~VIEWPORT") (cons 410 tab))))
                    (setq lst (LM:GetFiles "Select Drawings to Copy to" "" "dwg;dwt;dws"))
            (princ "\n*Cancel*")
        (   (progn
                (setq dbx
                    (vl-catch-all-apply 'vla-getinterfaceobject
                        (list (setq app (vlax-get-acad-object))
                            (if (< (setq vrs (atoi (getvar 'acadver))) 16)
                                "objectdbx.axdbdocument" (strcat "objectdbx.axdbdocument." (itoa vrs))
                (or (null dbx) (vl-catch-all-error-p dbx))
            (prompt "\nUnable to interface with ObjectDBX.")
        (   t
            (vlax-for doc (vla-get-documents app)
                (setq dwl (cons (cons (strcase (vla-get-fullname doc)) doc) dwl))
            (repeat (setq inc (sslength sel))
                (setq var (cons (vlax-ename->vla-object (ssname sel (setq inc (1- inc)))) var))
            (setq var
                (vlax-make-variant
                    (vlax-safearray-fill
                        (vlax-make-safearray vlax-vbobject (cons 0 (1- (length var)))) var
            (foreach dwg lst
                (if
                    (or (setq doc (cdr (assoc (strcase dwg) dwl)))
                        (and (not (vl-catch-all-error-p (vl-catch-all-apply 'vla-open (list dbx dwg))))
                             (setq doc dbx)
                        (vla-copyobjects acd var
                            (vla-get-block
                                (cond
                                    (   (_getitem (vla-get-layouts doc) tab))
                                    (   (vla-add  (vla-get-layouts doc) tab))
                        (vla-saveas doc dwg)
                        (setq cnt (1+ cnt))
                    (princ (apply 'strcat (cons "\nUnable to interface with file: " (cdr (fnsplitl dwg)))))
            (setq msg
                (if (< 0 cnt)
                    (strcat "\n"
                        (itoa (sslength sel))
                        (if (= 1 (sslength sel))
                            " object"
                            " objects"
                        " copied to " (itoa cnt)
                        (if (= 1 cnt)
                            " drawing."
                            " drawings."
            (if (< 0 (setq err (- (length lst) cnt)))
                (setq msg
                    (strcat msg
                        "\nUnable to copy to" (itoa err)
                        (if (= 1 err)
                            " drawing."
                            " drawings."
            (princ msg)
            (if (= 'vla-object (type dbx))
;;------------------------=={ Get Files Dialog }==----------------------;;
;;  An analog of the 'getfiled' function for multiple file selection.   ;;
;;  Author:  Lee Mac, Copyright © 2012  -  www.lee-mac.com              ;;
;;  Arguments:                                                          ;;
;;  msg - [str/nil] Dialog box label; 'Select Files' if nil or "".      ;;
;;  def - [str/nil] Default directory; dwgprefix if nil or "".          ;;
;;  ext - [str/nil] File extension filter (e.g. "dwg;lsp"); "*" if nil  ;;
;;  Returns:  List of selected files, else nil                          ;;
;;  Version 1.6    -    2016-03-21                                      ;;
(defun LM:getfiles ( msg def ext / *error* dch dcl des dir dirdata lst rtn )
        (if (= 'file (type des))
            (close des)
        (if (and (= 'int (type dch)) (< 0 dch))
            (unload_dialog dch)
        (if (and (= 'str (type dcl)) (findfile dcl))
            (vl-file-delete dcl)
        (if (and msg (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*")))
    (if
        (and
            (setq dcl (vl-filename-mktemp nil nil ".dcl"))
            (setq des (open dcl "w"))
                (foreach x
                        "lst : list_box"
                        "    width = 40.0;"
                        "    height = 20.0;"
                        "    fixed_width = true;"
                        "    fixed_height = true;"
                        "    alignment = centered;"
                        "    multiple_select = true;"
                        "but : button"
                        "    width = 20.0;"
                        "    height = 1.8;"
                        "getfiles : dialog"
                        "    key = \"title\"; spacer;"
                        "    : row"
                        "        : edit_box { key = \"dir\"; label = \"Folder:\"; }"
                        "        : button"
                        "            key = \"brw\";"
                        "            label = \"Browse\";"
                        "    spacer;"
                        "    : row"
                        "        : column"
                        "            : lst { key = \"box1\"; }"
                        "            : but { key = \"add\" ; label = \"Add Files\"; }"
                        "        : column {"
                        "            : lst { key = \"box2\"; }"
                        "            : but { key = \"del\" ; label = \"Remove Files\"; }"
                        "    spacer; ok_cancel;"
                    (write-line x des)
                (setq des (close des))
                (< 0 (setq dch (load_dialog dcl)))
            (new_dialog "getfiles" dch)
            (setq ext (if (= 'str (type ext)) (LM:getfiles:str->lst (strcase ext) ";") '("*")))
            (set_tile "title" (if (member msg '(nil "")) "Select Files" msg))
            (set_tile "dir"
                (setq dir
                    (LM:getfiles:fixdir
                        (if (or (member def '(nil "")) (not (vl-file-directory-p (LM:getfiles:fixdir def))))
                            (getvar 'dwgprefix)
                            def
            (setq lst (LM:getfiles:updatefilelist dir ext nil))
            (mode_tile "add" 1)
            (mode_tile "del" 1)
            (action_tile "brw"
                (vl-prin1-to-string
                   '(if (setq tmp (LM:getfiles:browseforfolder "" nil 512))
                        (setq lst (LM:getfiles:updatefilelist (set_tile "dir" (setq dir tmp)) ext rtn)
                              rtn (LM:getfiles:updateselected dir rtn)
            (action_tile "dir"
                (vl-prin1-to-string
                   '(if (= 1 $reason)
                        (setq lst (LM:getfiles:updatefilelist (set_tile "dir" (setq dir (LM:getfiles:fixdir $value))) ext rtn)
            (action_tile "box1"
                (vl-prin1-to-string
                        (lambda ( / itm tmp )
                            (if (setq itm (mapcar '(lambda ( n ) (nth n lst)) (read (strcat "(" $value ")"))))
                                (if (= 4 $reason)
                                    (cond
                                        (   (equal '("..") itm)
                                            (setq lst (LM:getfiles:updatefilelist (set_tile "dir" (setq dir (LM:getfiles:updir dir))) ext rtn)
                                        (   (vl-file-directory-p (setq tmp (LM:getfiles:checkredirect (strcat dir "\\" (car itm)))))
                                        (   (setq rtn (LM:getfiles:sort (append rtn (mapcar '(lambda ( x ) (strcat dir "\\" x)) itm)))
                                                  lst (LM:getfiles:updatefilelist dir ext rtn)
                                    (if (vl-every '(lambda ( x ) (vl-file-directory-p (strcat dir "\\" x))) itm)
                                        (mode_tile "add" 1)
                                        (mode_tile "add" 0)
            (action_tile "box2"
                (vl-prin1-to-string
                        (lambda ( / itm )
                            (if (setq itm (mapcar '(lambda ( n ) (nth n rtn)) (read (strcat "(" $value ")"))))
                                (if (= 4 $reason)
                                    (setq rtn (LM:getfiles:updateselected dir (vl-remove (car itm) rtn))
                                    (mode_tile "del" 0)
            (action_tile "add"
                (vl-prin1-to-string
                        (lambda ( / itm )
                            (if
                                (setq itm
                                    (vl-remove-if 'vl-file-directory-p
                                        (mapcar '(lambda ( n ) (nth n lst)) (read (strcat "(" (get_tile "box1") ")")))
                            (mode_tile "add" 1)
                            (mode_tile "del" 1)
            (action_tile "del"
                (vl-prin1-to-string
                        (lambda ( / itm )
                            (if (setq itm (read (strcat "(" (get_tile "box2") ")")))
                                (setq rtn (LM:getfiles:updateselected dir (LM:getfiles:removeitems itm rtn))
                            (mode_tile "add" 1)
                            (mode_tile "del" 1)
            (if (zerop (start_dialog))
                (setq rtn nil)
    (*error* nil)
    rtn
(defun LM:getfiles:listbox ( key lst )
    (start_list key)
    (foreach x lst (add_list x))
    (end_list)
    lst
(defun LM:getfiles:listfiles ( dir ext lst )
    (vl-remove-if '(lambda ( x ) (member (strcat dir "\\" x) lst))
        (cond
            (   (cdr (assoc dir dirdata)))
            (   (cdar
                    (setq dirdata
                        (cons
                            (cons dir
                                (append
                                    (LM:getfiles:sortlist (vl-remove "." (vl-directory-files dir nil -1)))
                                    (LM:getfiles:sort
                                        (if (member ext '(("") ("*")))
                                            (vl-directory-files dir nil 1)
                                            (vl-remove-if-not
                                                (function
                                                    (lambda ( x / e )
                                                        (and
                                                            (setq e (vl-filename-extension x))
                                                            (setq e (strcase (substr e 2)))
                                                            (vl-some '(lambda ( w ) (wcmatch e w)) ext)
                            dirdata
(defun LM:getfiles:checkredirect ( dir / itm pos )
    (cond
        (   (vl-directory-files dir) dir)
        (   (and
                (=  (strcase (getenv "UserProfile"))
                    (strcase (substr dir 1 (setq pos (vl-string-position 92 dir nil t))))
                (setq itm
                    (cdr
                        (assoc (substr (strcase dir t) (+ pos 2))
                                ("my documents" . "Documents")
                                ("my pictures"  . "Pictures")
                                ("my videos"    . "Videos")
                                ("my music"     . "Music")
                (vl-file-directory-p (setq itm (strcat (substr dir 1 pos) "\\" itm)))
            itm
        (   dir   )
(defun LM:getfiles:sort ( lst )
    (apply 'append
        (mapcar 'LM:getfiles:sortlist
            (vl-sort
                (LM:getfiles:groupbyfunction lst
                    (lambda ( a b / x y )
                        (and
                            (setq x (vl-filename-extension a))
                            (setq y (vl-filename-extension b))
                            (= (strcase x) (strcase y))
                (function
                        (and
                            (setq x (vl-filename-extension (car a)))
                            (setq y (vl-filename-extension (car b)))
                            (< (strcase x) (strcase y))
(defun LM:getfiles:sortlist ( lst )
    (mapcar (function (lambda ( n ) (nth n lst)))
        (vl-sort-i (mapcar 'LM:getfiles:splitstring lst)
            (function
                    (while
                        (and
                            (setq x (car a))
                            (setq y (car b))
                            (= x y)
                        (setq a (cdr a)
                              b (cdr b)
                    (cond
                        (   (null x) b)
                        (   (null y) nil)
                        (   (and (numberp x) (numberp y)) (< x y))
                        (   (numberp x))
                        (   (numberp y) nil)
                        (   (< x y))
(defun LM:getfiles:groupbyfunction ( lst fun / tmp1 tmp2 x1 )
    (if (setq x1 (car lst))
            (foreach x2 (cdr lst)
                (if (fun x1 x2)
                    (setq tmp1 (cons x2 tmp1))
                    (setq tmp2 (cons x2 tmp2))
            (cons (cons x1 (reverse tmp1)) (LM:getfiles:groupbyfunction (reverse tmp2) fun))
(defun LM:getfiles:splitstring ( str )
        (lambda ( l )
            (read
                (strcat "("
                    (vl-list->string
                        (apply 'append
                            (mapcar
                                (function
                                    (lambda ( a b c )
                                        (cond
                                            (   (member b '(45 46 92))
                                                (list 32)
                                            (   (< 47 b 58)
                                                (list b)
                                            (   (list 32 34 b 34 32))
                                (cons nil l) l (append (cdr l) '(( )))
        (vl-string->list (strcase str))
(defun LM:getfiles:browseforfolder ( msg dir flg / err fld pth shl slf )
    (setq err
        (vl-catch-all-apply
            (function
                (lambda ( / app hwd )
                    (if (setq app (vlax-get-acad-object)
                              shl (vla-getinterfaceobject app "shell.application")
                              hwd (vl-catch-all-apply 'vla-get-hwnd (list app))
                              fld (vlax-invoke-method shl 'browseforfolder (if (vl-catch-all-error-p hwd) 0 hwd) msg flg dir)
                        (setq slf (vlax-get-property fld 'self)
                              pth (LM:getfiles:fixdir (vlax-get-property slf 'path))
    (if slf (vlax-release-object slf))
    (if fld (vlax-release-object fld))
    (if shl (vlax-release-object shl))
    (if (vl-catch-all-error-p err)
        (prompt (vl-catch-all-error-message err))
        pth
(defun LM:getfiles:full->relative ( dir path / p q )
    (setq dir (vl-string-right-trim "\\" dir))
    (cond
        (   (and
                (setq p (vl-string-position 58  dir))
                (setq q (vl-string-position 58 path))
                (/= (strcase (substr dir 1 p)) (strcase (substr path 1 q)))
            path
        (   (and
                (setq p (vl-string-position 92  dir))
                (setq q (vl-string-position 92 path))
                (= (strcase (substr dir 1 p)) (strcase (substr path 1 q)))
            (LM:getfiles:full->relative (substr dir (+ 2 p)) (substr path (+ 2 q)))
        (   (and
                (= (strcase dir) (strcase (substr path 1 q)))
            (strcat ".\\" (substr path (+ 2 q)))
        (   (= "" dir)
            path
        (   (setq p (vl-string-position 92 dir))
            (LM:getfiles:full->relative (substr dir (+ 2 p)) (strcat "..\\" path))
        (   (LM:getfiles:full->relative "" (strcat "..\\" path)))
(defun LM:getfiles:str->lst ( str del / pos )
    (if (setq pos (vl-string-search del str))
        (cons (substr str 1 pos) (LM:getfiles:str->lst (substr str (+ pos 1 (strlen del))) del))
        (list str)
(defun LM:getfiles:updatefilelist ( dir ext lst )
    (LM:getfiles:listbox "box1" (LM:getfiles:listfiles dir ext lst))
(defun LM:getfiles:updateselected ( dir lst )
    (LM:getfiles:listbox "box2" (mapcar '(lambda ( x ) (LM:getfiles:full->relative dir x)) lst))
    lst
(defun LM:getfiles:updir ( dir )
    (substr dir 1 (vl-string-position 92 dir nil t))
(defun LM:getfiles:fixdir ( dir )
    (vl-string-right-trim "\\" (vl-string-translate "/" "\\" dir))
(defun LM:getfiles:removeitems ( itm lst / idx )
    (setq idx -1)
    (vl-remove-if '(lambda ( x ) (member (setq idx (1+ idx)) itm)) lst)
(vl-load-com)
(princ
    (strcat
        "\n:: Copy2Drawings.lsp | Version 1.3 | \\U+00A9 Lee Mac "
        (menucmd "m=$(edtime,0,yyyy)")
        " www.lee-mac.com ::"
        "\n:: Type \"c2dwg\" to Invoke ::"
;;                             End of File                              ;;
Thanks for any help.
This is my copy to all layouts lisp. Only works when your in a layout tab else it gives you an error message.
I guess you can run his then this ?
;; Copy object(s) To All Layouts (excluding current and Model)
(defun C:CTAL (/ _ss2lst llst olst doc)
  (vl-load-com)
  (defun _ss2lst (ss / i l)
    (if ss
        (setq l (cons (vlax-ename->vla-object (ssname ss (setq i (1- i)))) l))
  (vla-startundomark (setq doc (vla-get-activedocument (vlax-get-acad-object))))
  (if (eq (getvar 'CVPORT) 1)
      (princ "\nSelect object(s) to copy to all other layouts: ")
      (if (setq llst (list "Model" (getvar 'CTAB))
                olst (_ss2lst (ssget "_:L" (list (cons 410 (getvar 'CTAB)))))
        (vlax-for layout (vla-get-layouts *AcadDoc*)
          (if (not (member (vla-get-name layout) llst))
            (vlax-invoke *AcadDoc* 'CopyObjects olst (vla-get-block layout))
    (alert "Command Cannot be Executed in ModelSpace!")
  (vla-EndUndoMark doc)
Edited by mhupp
Thanks mhupp, I get the following error while trying your lisp "; error: bad argument type: VLA-OBJECT nil". However, I don't believe its what I was looking for unfortunately. I'm interested in inserting a block / blocks at the same coordinates as the source to multiple drawings at once. It would paste the block / blocks into all layouts excluding model space if more than one layout exists in the destination drawings. Hopefully that explains it better.
Thanks for the quick response though.
This is a copy objects to layouts that I have used, By Alan J Thomson.
I do what you want getting a block from a known dwg then copying it to all layouts.
Using a script it may be possible to do this for multiple dwg's, the code uses DBX to add a block to the block table. This is then copied to the layouts.
The one thing missing is how do you select block to copy, do you know its name and what dwg it is located in ?
(defun c:CTAL (/ *error* _ss2lst llst olst)
  ;; Alan J. Thompson, 11.23.11 / 2012.09.05
  (vl-load-com)
  (defun *error* (msg)
    (and *AcadDoc* (vla-endundomark *AcadDoc*))
    (if (and msg (not (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*QUIT*,")))
    (if ss
  (vla-startundomark
    (cond (*AcadDoc*)
          ((setq *AcadDoc* (vla-get-activedocument (vlax-get-acad-object))))
    (progn (princ "\nSelect object(s) to copy to all other layouts: ")
    (alert "\n ** Command cannot be executed in ModelSpace! **")
  (*error* nil)
This was done for a client so it may cost you a six pack, as it would need to be modified and tested.
Thanks BIGAL for the reply. I am aware of the copy to all layouts lisp, but not sure how this is suppose to insert blocks to other drawings. Lee Mac's code above does almost exactly of what I was hoping for with the exception of creating a new Layout tab in the destination drawings (drawings where the blocks are copied to).
Since I've gotten responses from experienced members, I assume this is not as easy as I initally thought. Thanks for trying to help out regardless.
So please explain what is being copied ? Is it all objects in say Model space then that can be done fairly simple using a ssget and extmin & extmax. Ot is it objects in a layout again can be done using a ssget with (cons 410 (getvar 'ctab))
