Not sure if it is called 'Attributes' or not. I have an existing drawing. Al the text is 'Attributes' I.e. if I double click it, box opens saying "Enter new name or size" etc. However I cannot have spaces in there (yet the existing attribute texts have spaces in them), so is there a workaround for this?
If you cannot enter spaces, it's likely to be an ATTDEF (attribute definition) tag.
Have you listed the object to verify what it is?
Either you have opened a block rather than inserted it or a block has been exploded. There is no easy way to convert those entries to text but if you intentionally exploded a block, next time use BURST instead (unless you have LT)
When you explode a block the ATTDEFs drop out and display their TAG which cannot contain spaces. Their text field can contain spaces.
