Hi,
I am trying to create a dynamic block for grades and slopes. I want to add an attributed text or field that changes as the slope of the line changes. so it can be a 1 in whatever the slope of the line is
See this page. I was able to create an mtext field inside a dynamic block, using the Angle property of a line Object. You can apply a rotation property/action and rotate the line/mtext inside the block. You have to Regen to update the field after you rotate it, but it works.
Welcome to the forum!
Do you need a dynamic block ? You can pick 2 points and just label.
