Please help to break closed polylines at corners
Please , I need help to break closed polylines at corners only, not all vertices.
As shown in the attached picture.
Test.dwg
Edited by Engineer_Yasser
[XDrX-PlugIn(141)] break closed polylines at corners (theswamp.org)
https://www.theswamp.org/index.php?topic=59452
1.The API provides a ready-made method for calculating the angle between each segment of a polyline.
(xdrx-getpropertyvalue pline "allinnerangles")
(xdrx-getpropertyvalue pline "allouterangles")
(xdrx-getpropertyvalue pline "angles")
2.Get the vertices whose angle between segments is not 0 or PI, and then use xdrx-curve-getsplitcurves to break.
(defun c:xdtb_plbrkatcorner (/ angles pts ss x y)
  (if (setq ss (xdrx-ssget (xdrx-string-multilanguage "\n选择多段线<退出>:" "\nSelect Polylines<Exit>:") '
			   ((0 . "*polyline"))
      (xdrx-begin)
      (mapcar
	'(lambda (x)
	   (setq angles (xdrx-getpropertyvalue x "vertices" "angle")
		 angles (mapcar
			  '(lambda (x y)
			     (list x y)
			  (car angles)
			  (cadr angles)
		 angles (vl-remove-if (function (lambda (x)
						  (or
						    (equal (last x) 0.0 1e-5)
						    (equal (last x) pi 1e-5)
				      ) angles
		 pts (mapcar
		       'car
		       angles
	   (xdrx-curve-getsplitcurves x pts)
	(xdrx-ss->ents ss)
      (xdrx-end)
			   ((0 . "*polyline"))
      (xdrx-begin)
      (mapcar
	'(lambda (x)
		 angles (mapcar
			  '(lambda (x y)
			     (list x y)
			  (car angles)
			  (cadr angles)
						  (or
				      ) angles
		 pts (mapcar
		       'car
		       angles
	(xdrx-ss->ents ss)
      (xdrx-end)
Thanks For Your Help 😍
