Error with isp that opens explorer window.
Hi all, I've been using AutoCAD for a while now but am only just beginning to learn how to use AutoLISP.
I have created a lisp that opens an explorer window showing the location of the currently open file:
(command "start" (strcat "explorer " (getvar "dwgprefix")))
My problem is that when I open certain files I receive an error dialog stating that:
"The path 'file path' does not exist or is not a directory."
This only occurs when the file path is quite long (over approx 40 characters).
Is there a way that I can fix this?
Thanks in advance
Is now really a good time to initiate your LISP skillset?
Hi toffeemilkshake,
Welcome to the forum
Seems to work fine. I just tested it with a path 142 characters long with no errors produced. I actually use a similar code myself which achieves the same thing
(startapp "explorer" (getvar "dwgprefix"))
The only time I come across erroe message
is when the directory does not exist
Are there any other parts to your routine?
Regards,
-Jammie
Hi Jammie,
Thanks for the response.
There are no other parts within my routine so I have no idea what's wrong with it.
However I did try using your code and everything seems to work fine that way.
Regards,
tm
Hi Jammie,
Regards,
tm
Your welcome toffeemilkshake,
I am not sure why your original code caused an error but glad I could be of some help
Regards,
-Jammie
