copy/edit text
masterfal
^C^C._SELECT;$M=$(if,$(eq,$(getvar,cmdnames),SELECT),_SI;\,(ssget);_SI;\)._COPY;_P;;\\._TEXTEDIT;_L;;
Hi All,
The simple macro above copies text and then after pasting brings up the edit text box. Is it possible to set this up as a lisp routine so i can set up a shortcut for quick use? Or does anyone have a similar lisp routine they can share? Thanks in advance!
This should work.
(defun c:pp()
  (setq txt (car (entsel)))
  (cond ((and txt (= (cdr (assoc 0 (entget txt))) "TEXT"))
	 (command "copy" txt "" pause pause)
	 (command "textedit" "L" "")
	(t "wrong selection"))
It can be improved...
yeh that works good. how can i amend so it includes "MTEXT" also? it works with MTEXT when i change the TEXT to that. i thought adding MTEXT there would add that option but it stops it working properly..  🤔
The macro copies the Mtext, and then, after pasting, opens the text editor
^C^C_Copy;\;@;\_MTEDIT;_Last
Edited by Nikon
3 minutes ago, Nikon said:
The macro copies the Mtext, and then, after pasting, opens the edit Mtext field
yeh the macro i pasted in original post did that as well as working with single line text
i'm trying to work out how to achieve the same via lisp
there is a slight difference between macros for MTEXT...
Edited by Nikon
Fuccaros code tests for text being selected, if you want text OR mtext you need to change the check line:
to include (or....)
Untested replace with something like this:
(cond ((and txt
  (or
    (= (cdr (assoc 0 (entget txt))) "MTEXT")
  ) ; endor
 ) ; end and
I wrote the Lisp above to deal with texts according to OP's request. So the program checks first if there is anything selected, next it looks for the type of the selected entity.
Yes, you can expand that second check by adding some ORs, or you could use wildcards.
Another option could be to skip all these checks. Of course, in this case it is the user's responsibility to make correct selections.
i tweaked the code to include the (or...) as per Steven P suggestion and now it works perfect 👍
thanks for the help guys. much appreciated
another way as fuccaro stated using wildcards:
(cond ((and txt (wcmatch (cdr (assoc 0 (entget txt))) "TEXT,MTEXT"))
There are many ways to skin this cat :)
(cond ((and txt (wcmatch (cdr (assoc 0 (entget txt))) "*TEXT"))
also works.
  • Like 2
If you replace this string
with
(command "MTEDIT" "L" "")
a copy of the mtext in the editor will be highlighted
Edited by Nikon
