Language Settings...
Hello,
I had to install Autocad2009 on a new computer at work, all seamed to be well untill i started drawing and found i have installed it with english us language settings not uk. How do I change it to uk? Feeling realy frustrated.
Thanks in advance.
Forgive me if I'm wrong, and I might be completely off my bat here - but are you sure that there is a UK and US version? How do you tell that you got the wrong one?
Ok when I went to my computer this morning the keybord settings had reverted back to UK and have been fine all day. Am now confused as to why this happened in the first place considering I rebooted 3 time after initial instilation...
On the US keyboard the@ key is where you would find the " key so when your used to working with one type it's very annoying to switch.:?
Just a curiosity now rather than an urgent matter:)
Are you sure the problem comes from AutoCAD? You can have multiple languages installed on your computer and use Alt+Shift to switch them. Also if the language is shown in the task bar, click it and you will see the options to choose an other one.
Yeah, that does sound more like a keyboard setting. I know that I have switched my keyboard from Sweidsh to English a couple of times, extremely annoying, I loose some letters and the symbols get switched around. I think there is a key-combination that you press that switches it, can't remember what it is now though.
