ILoveMadoka Posted March 10, 2009 Posted March 10, 2009 Autocad 2009 When you go into the Plot dialog, Under Printer/plotter there is a drop down between Name: and the Properties button. On my machine there are all sorts of printer names there. I'd love to prune this list down to the only 2 printers that I actually print to. Is this possible? Can some explain? Is there a location where that list is pulling from? Could someone kindly point me to it? I have found some default printers here: C:\Documents and Settings\UserName\Application Data\Autodesk\AutoCAD 2009\R17.2\enu\Plotters ie: WF6 ePlot.pc3 | Default Windows System Printer.pc3 But not the ones I want to delete... Help Please!!! Quote
rkent Posted March 10, 2009 Posted March 10, 2009 Options, Files, Printer support file path, finally Printer Configuration Search Path Also you might go to Options, Plot and Publish, check Hide System printers. Quote
