First post. Can the DXE file be in any order or  is it stuck just ascending or descending?
I guess it depends on which version you're using. At some point the wizard that creates your DXE file should give you the option of sorting on a column. You pick the column(s) and specify ascending or descending order.
If that doesn't help, please provide more information. How are you creating the DXE file? What types of data are you extracting, and what are you doing with the data?
Welcome to the forum!
