greatsyd Posted April 29, 2024 Posted April 29, 2024 Does anybody have a LISP for creating slope lines / batter lines? Thank you very much! Quote
SLW210 Posted April 29, 2024 Posted April 29, 2024 I have moved your thread to the AutoLISP, Visual LISP & DCL Forum. Please post in the most appropriate forum. Quote
fuccaro Posted April 29, 2024 Posted April 29, 2024 Years ago there were some posts about this. Read here, maybe you can get some help from: Quote
XDSoft Posted May 1, 2024 Posted May 1, 2024 (edited) [XDrX-PlugIn(158)] Draw slope lines (theswamp.org) https://www.theswamp.org/index.php?topic=59524.0 (defun c:xdtb_slopeline (/ an anbase arc1 bEnd c_pt cir1 cir2 e e1 e2 ept ept1 ept2 even-list even-pair g int1 ints lastent lastents lst m midp mLn1 mLn2 mLn3 mode n_pt nearpt1 nearpt2 odd-list p1 p2 pnt pt r1 r2 spt1 spt2 ss temp temp1 top-pts1 vec1 vec2 x ) (defun _get-perp-point (crv pnt) (mapcar '+ pnt (xdrx-vector-perpvector (xdrx-curve-getfirstderiv e1 pnt)) ) ) (defun _get-point (e pt / p1) (setq p1 (_get-perp-point e pt)) (if (setq ints (xdrx-entity-intersectwith (list pt p1) e2 1)) (car ints) ) ) (defun _get-next-circle-inters () (if (and (setq n_pt (cadr (member c_pt even-list))) (setq int1 (_get-point e1 n_pt)) ) (progn (setq r2 (distance n_pt int1) cir2 (xdrx-circle-make int1 r2) ) (setq lastents (cons cir2 lastents)) (setq ints (xdrx-entity-intersectwith cir1 cir2)) (setq nearpt2 (xdrx-points-nearpt c_pt ints)) ) (progn (setq bEnd t m (xdrx-matrix-setmirror (list c_pt midp)) nearpt2 (xdrx-point-transform nearpt1 m) ) ) ) ) (defun _get-appropriate-angle () (setq vec1 (mapcar '- nearpt1 midp ) vec2 (mapcar '- nearpt2 midp ) ) (setq anbase (angle midp c_pt) an (xdrx-vector-angle vec2 vec1) ) (if (> an #xd-var-global-slope-Angle) (progn (setq p1 (polar midp (+ anbase (/ #xd-var-global-slope-Angle 2.0)) (distance midp c_pt) ) temp1 (xdrx-entity-intersectwith (list midp p1) cir1 1) nearpt1 (xdrx-points-nearpt p1 temp1) ) (if (not bEnd) (progn (setq p2 (polar midp (- anbase (/ #xd-var-global-slope-Angle 2.0)) (distance midp c_pt) ) temp1 (xdrx-entity-intersectwith (list midp p2) cir1 1) nearpt2 (xdrx-points-nearpt p2 temp1) ) ) (setq nearpt2 (xdrx-point-transform nearpt1 m)) ) ) ) ) (defun _draw-slope-line () (setq g (xdrx-curve-setinterval cir1 nearpt1 nearpt2)) (setq arc1 (xdrx-entity-make g)) (setq mLn1 (xdrx-line-make temp midp) mLn2 (xdrx-line-make midp (xdrx-curve-getstartpoint arc1) ) mLn3 (xdrx-line-make (xdrx-curve-getendpoint arc1) midp ) ) (xdrx-curve-join (list mLn1 mLn2 arc1 mLn3)) (if (= #xd-var-global-slope-mode "1") (progn (xdrx-polyline-setbulgeat (entlast) 1 #xd-var-global-bulge ) (xdrx-polyline-setbulgeat (entlast) 3 #xd-var-global-bulge ) ) ) ) (defun _draw-slope-1 () (xdrx-line-make (car top-pts1) (xdrx-curve-getstartpoint e2)) (setq lastent (entlast) lastents (cons lastent lastents) bEnd nil ) (mapcar '(lambda (x) (setq c_pt x) (if (setq int1 (_get-point e1 c_pt)) (progn (setq temp int1 midp (xdrx-line-midp c_pt temp) ) (setq r1 (distance c_pt int1) cir1 (xdrx-circle-make int1 r1) ) (setq lastents (cons cir1 lastents)) (if (setq ints (xdrx-entity-intersectwith cir1 lastent)) (progn (setq nearpt1 (xdrx-points-nearpt c_pt ints)) (setq nearpt2 (_get-next-circle-inters)) (_get-appropriate-angle) (_draw-slope-line) (xdrx-entity-delete cir2) (setq lastent cir1) ) ) ) ) ) even-list ) (xdrx-entity-delete lastents) ) (defun _draw-short-slope-line (lst) (mapcar '(lambda (x) (setq p1 (_get-perp-point e1 x)) (if (setq ints (xdrx-entity-intersectwith (list x p1) e2 1)) (progn (xdrx-line-make x (xdrx-line-midp x (car ints))) ) ) ) lst ) ) (defun _draw-slope-0 () (xdrx-line-make (car top-pts1) (xdrx-curve-getstartpoint e2)) (mapcar '(lambda (x) (setq p1 (_get-perp-point e1 x)) (if (setq ints (xdrx-entity-intersectwith (list x p1) e2 1)) (progn (xdrx-line-make x (car ints)) (setq ept x) ) ) ) (cdr odd-list) ) (_draw-short-slope-line even-list) ) ; main (setq #xd-var-global-bulge -0.2 ; BULGE values of arc segments on ; both sides #xd-var-global-slope-color 8 #xd-var-global-slope-Angle (/ pi 2.25) ; max angle on both sides; ) ; Modify the color index you need (if (not #xd-var-global-slope-mode) (setq #xd-var-global-slope-mode "1") ) (xdrx-begin) (xdrx-sysvar-push '("RetEntList" 1)) (xd::doc:getdouble (xdrx-string-multilanguage "\n坡线间距" "\nSlope Line Gap" ) "#xd-var-global-slope-gap" 10.0 ) (xdrx-initget 0 "0 1 2") (if (setq mode (getkword (xdrx-string-formatex (xdrx-string-multilanguage "\n坡度线模式[标准(0)/圆弧(1)/模式(2)]<1>" "\nSlope line mode[standard(0)/arc(1)/mode(2)]<%s>") #xd-var-global-slope-mode ) ) ) (setq #xd-var-global-slope-mode mode) ) (xdrx-initget) (if (and (setq e1 (car (xdrx-entsel (xdrx-string-multilanguage "\n拾取坡顶线<退出>:" "\nPick top line<Exit>:") '((0 . "*polyline,line") (-4 . "<not") (-4 . "&=") (70 . 1) (-4 . "not>") ) ) ) ) (setq e2 (car (xdrx-entsel (xdrx-string-multilanguage "\n拾取坡底线<退出>:" "\nPick down line<Exit>:") '((0 . "*polyline,line") (-4 . "<not") (-4 . "&=") (70 . 1) (-4 . "not>") ) ) ) ) ) (progn (xdrx-setmark) (setq spt1 (xdrx-curve-getstartpoint e1) ept1 (xdrx-curve-getendpoint e1) spt2 (xdrx-curve-getstartpoint e2) ept2 (xdrx-curve-getendpoint e2) ) (if (< (distance spt1 ept1) (distance spt1 spt2)) (xdrx-curve-reverse e2) ) (setq top-pts1 (xdrx-curve-getpointsatdist e1 (/ #xd-var-global-slope-gap 2.0 ) ) even-list (xd::list:even top-pts1) even-pair (xd::list:snakepair top-pts1) odd-list (xd::list:odd top-pts1) ) (cond ((= #xd-var-global-slope-mode "0") (_draw-slope-0) ) (t (_draw-slope-1) ) ) (setq ss (xdrx-getss)) (xdrx-entity-setcolor ss #xd-var-global-slope-color) (xdrx_group_make "*" ss) ) ) (xdrx-sysvar-pop) (xdrx-end) (princ) ) ===================== The above code uses XDrx API, download link: https://github.com/xdcad/XDrx-API-zip https://sourceforge.net/projects/xdrx-api-zip/ Dual version link: https://github.com/xdcad Edited May 1, 2024 by XDSoft Quote
granat Posted 38 minutes ago Posted 38 minutes ago c:\program files (x86)\xdsoft\sys\xdrx.x64.25.arx cannot find a procedure that it needs. Quote
