I am using AutoCAD 2008. I am xrefing a Jpeg image (elevation). When I plot, the white background is printed as a dot pattern. Seems like the plotter is trying to print "white." How can i adjust the image to have a clear/clean background? Different file type? Anything?
Thank yoU!
-S
Start the IMAGEADJUST command and play around with the settings. Make it lighter. Also see if transparency turned on makes any difference.
Probable it worked... For just in case, if there are any non Romanian speakers around here: multumesc=thank you :)
