Hi, I am looking for some hepl regarding the .wdt and the .wdl files with autocad electrical. My work place uses a dropbox type network and i have set up the files along with a template drawing in a folder on this dropbox. We want to use the same titleblock for every new project and the same project descriptions. So my files are named <defaul.wdt> and <default_wdtitle.wdl>. I changed my support path within autocad electrical to read from this folder in the dropbox aswell as my .env file. Yet for some reason it only worked properly with the first project i did. Now every time i start a new project autocad throws out an error message saying that the .wdt file was not found. Any help would be much appreciated...
Not sure as don't use electrical but in CAD you can set the dwt to be used, try Options, Templates.
