ascen707 Posted March 13, 2009 Posted March 13, 2009 Hello my friends!! I have one questions? I had CAD 2000 in one computer and I upgraded that PC with CAD 2007. well everything is fine but one pen setting. I got this pen setting in CAD 2000 and I copy it over to CAD 2007 but the problem is that when I plot on CAD 2007 with that pen setting some line types are very light not the same like in CAD 2000. It works good in 2000 but in 2007 some line types are very light. I even try to set to plot by color, is there anything am missing. I double checked the line weights and the thickness and they both match. Am lost Please help!! Thank you!! Quote
Strix Posted March 13, 2009 Posted March 13, 2009 a complete stab in the dark, but do you have the most up to date plotter drivers? Quote
ascen707 Posted March 13, 2009 Author Posted March 13, 2009 Good point! Let me try that today and see if that works. THanks! Quote
rkent Posted March 13, 2009 Posted March 13, 2009 The only work around I am aware of is creating the file from 2007 rather than using one created from a previous release. Quote
tkelly Posted March 14, 2009 Posted March 14, 2009 As far as my information goes pen styles are not dependent on Autocad version . I am using pen styles which was used in Autocad 2000 version. Please check if the file is corrupted or changed. (Not sure) Quote
ReMark Posted March 15, 2009 Posted March 15, 2009 I second rkent's suggestion as you most likely have a corrupt plot style. Just out of curiosity, is this a .ctb or .stb? Quote
Coosbaylumber Posted March 15, 2009 Posted March 15, 2009 I am thinking here, but depending upon actual plotter manufacturer and model, can't you alter the settings directly for one pen on the control panel to the plotter? This it will over ride anything being set via software? Wm. Quote
ascen707 Posted March 16, 2009 Author Posted March 16, 2009 Well the pen setting are both .ctb and .stb. Thanks, Quote
rkent Posted March 16, 2009 Posted March 16, 2009 Well the pen setting are both .ctb and .stb. Thanks, Recreate them in 2007 and you won't have any other problems with this. Quote
