Is there a way to convert a 3d perspective view into a 2d dwg? I thought perhaps it could be done with live sectioning, but haven't been able to do it as of yet. I'm guessing if I could get my ucs set to the right angle it might work right...?
If I remember correctly, the way I've done it in the past is to save as a dxf binary option.
This results in all entities becoming line segments.
Look into DXB Plotting. Then DXBIN Not totally accurate but as it has not been updated since Release 10 and it is an integer based application. -David
Ah, maybe that's what I was thinking. I haven't done it in a long time.
I'm just guessing that it is still around. It was an add on in A2K. Hopefully it hasn't been totally abandoned. -David
You just became one of my favorite friends David. Thanks so much for this tip. :D
