veteranus Posted May 9, 2024 Posted May 9, 2024 Hello, Can I write to all my selected poyline, lines, rectangles or anything total lenght and area to a table with selected layer name. Example.dwg Quote
devitg Posted May 9, 2024 Posted May 9, 2024 (edited) 1 hour ago, veteranus said: Hello, Can I write to all my selected poyline, lines, rectangles or anything total lenght and area to a table with selected layer name. Example.dwg 100.69 kB · 2 downloads @veteranus you can use DATAEXTRACTION Example+dataextraction.dwg Edited May 9, 2024 by devitg add dwg Quote
BIGAL Posted May 10, 2024 Posted May 10, 2024 Try this, your lucky have code that sort of matches. ; make simple table of lines and plines ; by Alan H May 2024 (defun CreateTableStyle ( / dicts dictobj key class custobj ) ;; Get the Dictionaries collection and the TableStyle dictionary (setq dicts (vla-get-Dictionaries (vla-get-ActiveDocument(vlax-get-acad-object)))) (setq dictObj (vla-Item dicts "acad_tablestyle")) (setq txtht 0.07) (vlax-for dname dictobj (if (= (vla-get-name dname) "Veteranus" ) ; does it exist (setq Veteranus "No") ) ) (if (= Veteranus "No") (progn ;; Create a custom table style (setq key "Veteranus" class "AcDbTableStyle") (setq custObj (vla-AddObject dictObj key class)) ;; Set the name and description for the style (vla-put-Name custObj "Veteranus") (vla-put-Description custObj "Veteranus custom table style") ;; Sets the bit flag value for the style (vla-put-BitFlags custObj 1) ;; Sets the direction of the table, top to bottom or bottom to top (vla-put-FlowDirection custObj acTableTopToBottom) ;; Sets the horizontal margin for the table cells (vla-put-HorzCellMargin custObj (* txtht 0.1)) ;; Sets the vertical margin for the table cells (vla-put-VertCellMargin custObj (* txtht 0.2)) ;; Set the alignment for the Data, Header, and Title rows (vla-SetAlignment custObj (+ acDataRow acHeaderRow acTitleRow) acMiddleCenter) ;; Set the text height for the Title, Header and Data rows (vla-SetTextHeight custObj acDataRow txtht) (vla-SetTextHeight custObj acHeaderRow (* txtht 1.2)) (vla-SetTextHeight custObj acTitleRow (* txtht 1.5)) ;; Set the text height and style for the Title row (vla-SetTextStyle custObj (+ acDataRow acHeaderRow acTitleRow) "Standard") ; (vla-put-regeneratetablesuppressed custobj :vlax-false) ) ) ) (defun c:wow ( / sp vgms numrows numcolumns rowheight colwidth objtable x ss obj lay len area) (createtablestyle) (setvar 'ctablestyle "Veteranus") (setq sp (vlax-3d-point (getpoint "pick a point for table"))) (Setq vgms (vla-get-modelspace (vla-get-activedocument (vlax-get-acad-object)))) (setq numrows 3) (setq numcolumns 3) (setq rowheight 0.1) (setq colwidth 0.8) (setq objtable (vla-addtable vgms sp numrows numcolumns rowheight colwidth)) (vla-settext objtable 0 0 "BBQ") (vla-settext objtable 1 0 "Layername") (vla-settext objtable 1 1 "Tot Area (m2)") (vla-settext objtable 1 2 "Tot. Length (m)") (command "_zoom" "e") (setq ss (ssget '((0 . "Line,Lwpolyline")))) (if (= ss nil) (progn (alert "No lines or plines chosen\n\n will exit now")(exit)) ) (setq numrows 2) (repeat (setq x (sslength ss)) (setq obj (vlax-ename->vla-object (ssname ss (setq x (- x 1))))) (if (= (vlax-get obj 'objectname) "AcdbLINE") (progn (setq lay (vlax-get obj 'layer)) (setq parea "0.0") (setq len (rtos (vlax-get obj 'length) 2 2)) ) (progn (setq lay (vlax-get obj 'layer)) (setq parea (rtos (vlax-get obj 'area) 2 2)) (if (= parea "0")(setq parea "0.0")) (setq len (rtos (vlax-get obj 'length) 2 2)) ) ) (vla-InsertRows Objtable numrows 0.1 1) (vla-settext objtable numrows 0 lay) (vla-settext objtable numrows 1 pArea) (vla-settext objtable numrows 2 Len) (setq numrows (1+ numrows)) ) (princ) ) (c:wow) Quote
veteranus Posted May 10, 2024 Author Posted May 10, 2024 (edited) 4 hours ago, BIGAL said: Try this, your lucky have code that sort of matches. ; make simple table of lines and plines ; by Alan H May 2024 (defun CreateTableStyle ( / dicts dictobj key class custobj ) ;; Get the Dictionaries collection and the TableStyle dictionary (setq dicts (vla-get-Dictionaries (vla-get-ActiveDocument(vlax-get-acad-object)))) (setq dictObj (vla-Item dicts "acad_tablestyle")) (setq txtht 0.07) (vlax-for dname dictobj (if (= (vla-get-name dname) "Veteranus" ) ; does it exist (setq Veteranus "No") ) ) (if (= Veteranus "No") (progn ;; Create a custom table style (setq key "Veteranus" class "AcDbTableStyle") (setq custObj (vla-AddObject dictObj key class)) ;; Set the name and description for the style (vla-put-Name custObj "Veteranus") (vla-put-Description custObj "Veteranus custom table style") ;; Sets the bit flag value for the style (vla-put-BitFlags custObj 1) ;; Sets the direction of the table, top to bottom or bottom to top (vla-put-FlowDirection custObj acTableTopToBottom) ;; Sets the horizontal margin for the table cells (vla-put-HorzCellMargin custObj (* txtht 0.1)) ;; Sets the vertical margin for the table cells (vla-put-VertCellMargin custObj (* txtht 0.2)) ;; Set the alignment for the Data, Header, and Title rows (vla-SetAlignment custObj (+ acDataRow acHeaderRow acTitleRow) acMiddleCenter) ;; Set the text height for the Title, Header and Data rows (vla-SetTextHeight custObj acDataRow txtht) (vla-SetTextHeight custObj acHeaderRow (* txtht 1.2)) (vla-SetTextHeight custObj acTitleRow (* txtht 1.5)) ;; Set the text height and style for the Title row (vla-SetTextStyle custObj (+ acDataRow acHeaderRow acTitleRow) "Standard") ; (vla-put-regeneratetablesuppressed custobj :vlax-false) ) ) ) (defun c:wow ( / sp vgms numrows numcolumns rowheight colwidth objtable x ss obj lay len area) (createtablestyle) (setvar 'ctablestyle "Veteranus") (setq sp (vlax-3d-point (getpoint "pick a point for table"))) (Setq vgms (vla-get-modelspace (vla-get-activedocument (vlax-get-acad-object)))) (setq numrows 3) (setq numcolumns 3) (setq rowheight 0.1) (setq colwidth 0.8) (setq objtable (vla-addtable vgms sp numrows numcolumns rowheight colwidth)) (vla-settext objtable 0 0 "BBQ") (vla-settext objtable 1 0 "Layername") (vla-settext objtable 1 1 "Tot Area (m2)") (vla-settext objtable 1 2 "Tot. Length (m)") (command "_zoom" "e") (setq ss (ssget '((0 . "Line,Lwpolyline")))) (if (= ss nil) (progn (alert "No lines or plines chosen\n\n will exit now")(exit)) ) (setq numrows 2) (repeat (setq x (sslength ss)) (setq obj (vlax-ename->vla-object (ssname ss (setq x (- x 1))))) (if (= (vlax-get obj 'objectname) "AcdbLINE") (progn (setq lay (vlax-get obj 'layer)) (setq parea "0.0") (setq len (rtos (vlax-get obj 'length) 2 2)) ) (progn (setq lay (vlax-get obj 'layer)) (setq parea (rtos (vlax-get obj 'area) 2 2)) (if (= parea "0")(setq parea "0.0")) (setq len (rtos (vlax-get obj 'length) 2 2)) ) ) (vla-InsertRows Objtable numrows 0.1 1) (vla-settext objtable numrows 0 lay) (vla-settext objtable numrows 1 pArea) (vla-settext objtable numrows 2 Len) (setq numrows (1+ numrows)) ) (princ) ) (c:wow) Hello Bigal. Thanks for reply. I m getting this error and I have zero knowagle about autolisp ; error: AutoCAD variable setting rejected: CTABLESTYLE "Veteranus" Edit: After creating a table syle called Veteranus it worked. But, can it write total lenght and area of selected layers instead of by one by? Edited May 10, 2024 by veteranus Quote
