Bogbadbob658 Posted March 17, 2009 Posted March 17, 2009 Does anyone know how to adjust the the anchor within a window style. I know how to do it for an individual window but not for window style. The attached file shows 2 windows in a wall both using the same window style. I have adjusted the one to the left so that it is nearer to one edge. How do I adust it so that when I add a window using the same style it all ways appears like that and not as the one to the right? I hope that makes sense! Windows.dwg Quote
Noahma Posted March 18, 2009 Posted March 18, 2009 I do not know if you can actually do it by window style, but you can just add another of the same object. select the window and right click. Choose "add selected" and it will re run your window tool with everything that particular window had set for it. Quote
