In autocad 2008 when i open a new drawing, the global scale factor is set to 99.9. i change the scale factor to 1, but when i'm reopening the file, the global scale factor automatically changes to 99.9. of course, i want for the scale factor to remain 1.
do you know what can i do to solve this problem? thank you
What do you means ?..
Where is it?:glare::glare:
in the linetype manager window, under details is the "Global scale factor", which automatically changes to 99.9 after opening a drawing, even if this scale factor is set, before closing that file, to 1.
Sounds like the LTSCALE variable is being set upon start-up.
Check your ACADDOC.lsp or ACAD.lsp for lines that might be setting this variable to 99.9
something like
(setvar "LTSCALE" 99.9)
