Engineer_Yasser Posted June 1, 2024 Posted June 1, 2024 (edited) I select one Alignment and then select similar but all alignments selected (ssget (list (cons 0 "AECC_ALIGNMENT"))) I need to filter the selection to (Centerline Alignments only ) Edited June 1, 2024 by Engineer_Yasser Quote
BIGAL Posted June 3, 2024 Posted June 3, 2024 Not sure but the AECC_Alignment may have a secondary property. Try this select a couple of different ones at look at the difference in properties. (defun aecc ( / ss) (setq ss (ssget (list (cons 0 "AECC_ALIGNMENT")))) (repeat (setq x (sslength ss)) (vlax-dump-object (vlax-ename->vla-object (ssname ss (setq x (- x 1))))) ) (princ) ) (aecc) Quote
