mocxi Posted March 18, 2009 Posted March 18, 2009 Please help me in this question I have a pair of gear and the splined shaft. I would like to Motion simulation this assembly by Cosmosmotion then export the data to CosmosWork for FEA purpose (Solidwork 2007). But my problem is: I don't know which mates (coincident, parallel of concentric) are suitable for joint between splined shaft and gear (the gear hub is spined) Thank for your help Quote
shift1313 Posted March 18, 2009 Posted March 18, 2009 i would use a contact constraint once in the motion simulation. you will apply a torque to the shaft and the teeth engagement with your gear will create the motion. Before you go into the motion simulation i would add a concentric constraint to the shaft/gear pair Quote
