Hello
can anyone remember the hide hatch command?
my brain isnt working today cant remember it.
I am refering to the command that will turn off all hatches in a drawing xref or otherwise,
thank you
Never Heard Of It, Can Your Hatch Not Just Be On A Layer And Turn That Layer Off?
The FILLMODE command will turn off all filled objects including hatch.
thank you so obvious now DUH!
the good thing about fillmode is that it turns off all hatches on different layers one command multiple result
  • 4 years later...
Hmm, I just tried that. This does not work, perhaps I am comment on a old thread is the reason as to why this maybe.
Need a thank you button on here or I shall be spamming thank yous
  • 1 year later...
I was looking for my Map hatching problem. It almost solve when I find this thread with right solution. I have map with hatching but the problem is Hatches are not on same layers. I was looking to off my entire hatch in XREF. This FILLMODE command solved my problem.
Thank you SLW210 :notworthy:
