Updating Object Props from Object Data
I have imported a load of contour lines from shape files and also imported some object data with it (elevation) as the contours show and list as 2D lines.
Now I am trying to run a query to pull the elevation value from the object data to update the object elevation but the object data does not show in the expression dialogue box although it does in the drawing properties pane.
Could you provide any help on this please?
  • 3 weeks later...
Do you mean, if you click on your object, you can't see it elevation in the properties box?
