Altez Posted March 20, 2009 Posted March 20, 2009 I can't make a long plot (2.6 m) with true view 2009. The preview looks fine but when it comes out of the plotter (océ TDS 600) it has been scaled in the X-direction to fit on a paper a bit smaller than Din A0. The height stays correct. The plot and plotter setting are the same as in autocad (here everything is OK). Can somebody tell me how to solve this problem ? (True view is not installed on the same computer as autocad) thanks, Peter Quote
rkmcswain Posted March 20, 2009 Posted March 20, 2009 Are you using the same driver/PC3 file in TrueView as you are in AutoCAD? Quote
Altez Posted March 20, 2009 Author Posted March 20, 2009 Solved ! I configured a new LPR-port in WinXP and copied the driver from AutoCad. Thanks ! Quote
