Altez Posted March 20, 2009 Share Posted March 20, 2009 I can't make a long plot (2.6 m) with true view 2009. The preview looks fine but when it comes out of the plotter (océ TDS 600) it has been scaled in the X-direction to fit on a paper a bit smaller than Din A0. The height stays correct. The plot and plotter setting are the same as in autocad (here everything is OK). Can somebody tell me how to solve this problem ? (True view is not installed on the same computer as autocad) thanks, Peter Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted March 20, 2009 Share Posted March 20, 2009 Are you using the same driver/PC3 file in TrueView as you are in AutoCAD? Quote Link to comment Share on other sites More sharing options...
Altez Posted March 20, 2009 Author Share Posted March 20, 2009 Solved ! I configured a new LPR-port in WinXP and copied the driver from AutoCad. Thanks ! Quote Link to comment Share on other sites More sharing options...
