Hi i need help.
I want to move the base point of a block in the block editor. However, when I move it, the block moves accordingly in the drawing.
How can i move the base point in the editor, so that the block stays at the same position in the drawing.
tnx
Please do not double post. Thank you.
Maybe someone can prove me wrong but I don't think there is a way.
unless 2009 has brought in an enhancement, I agree with lpseifert.
This is why it is so important to specify the correct base point when defining your blocks.
type in BASE in the drawing of the block
which will move the base in exactly the way the OP doesn't want it to.
Hi i need help.
tnx
Draw a line from the old point to where the new one will be. Once you've redefined the base point, move all the other objects back along the temporary line you created.
Sounded a bit simple. Have I correctly inferred you requirements?
yeah i guess i can do that... its not an elegant soulution but hey...
  • 2 years later...
this lisp works perfect:
(defun c:bnpt ( / en p1 p2 a d bn)
(cond
((not (setq en (f:entselx
"INSERT" "\nSelect Insert to reposition insertion point: "))))
((not (setq p2
(getpoint (setq p1 (f:assoc 10 (setq en (car en)))) "\nNew position for
(T
(setq p2 (f:insert_trans en p2)
a (angle p2
p1)
d (distance p2 p1)
p1 (ftx p1)
p2 (ftx p2)
bn (f:assoc 2
en)
);setq
(vlax-map-Collection (f:vltblobjname 'Blocks bn
nil)
'(lambda (e)
(vla-Move e p2 p1)
(f:map_all:filter (list
(cons 0 "INSERT")(cons 2 bn))
(lambda (e)
(vla-Move e (ftx
(f:insert_polar e a d)) (vla-get-InsertionPoint
e))
(princ));defun
(setq #000 (list 0.0 0.0
0.0))
(setq #000x (vlax-3d-point (list 0.0 0.0 0.0)))
(defun f:entselx
(typ prm / e ini)
(if (listp prm)(setq ini (cadr prm) prm (car
prm)))
(setvar "ERRNO" 0)
(while (and (not e) (/= (getvar "ERRNO")
52))
(if ini (initget ini))
(setq e (entsel prm))
(cond
((= (type e)
'STR))
((/= (f:assoc 0 (car e)) typ)
(setq e
nil)
);cond
e)
(defun f:en (en)
(if (/= (type en)
'ENAME)
(vlax-vla-object->ename en)
en
(defun f:enx
(en)
(if (= (type en) 'ENAME)
(vlax-ename->vla-object
en)
en
(defun f:assoc (at lst / ret)
(cond
(type lst) 'ENAME)(setq lst (entget lst)))
((= (type lst) 'VLA-OBJECT)(setq
lst (entget (f:en lst))))
(if (and (f:assocp lst)
(setq ret (assoc at
lst))
);and
(cdr ret)
);if
(defun f:assocp
(lst)
(and
lst
(listp lst)
(not (vl-some '(lambda (at) (not
(vl-consp at))) lst))
(defun f:insert_trans (en pt /
p)
(setq p (f:assoc 10 en)
pt (polar #000 (- (angle p pt) (f:assoc 50 en))
(distance p pt))
pt (list (/ (car pt) (f:assoc 41 en)) (/ (cadr pt) (f:assoc
42 en)) (/ (caddr pt) (f:assoc 43 en)))
);setq
(polar p (angle #000 pt)
(distance #000 pt))
(defun f:insert_polar (en a d / pt)
(setq pt
(polar #000 a d)
pt (list (* (f:assoc 41 en) (car pt)) (* (f:assoc 42 en)
(cadr pt)) (* (f:assoc 43 en) (caddr pt)))
(polar (f:assoc 10 en) (+
(angle #000 pt) (f:assoc 50 en)) (distance #000 pt))
(defun ftx
(pt)
(if (= (type pt) 'variant)
pt
(vlax-3d-point
pt)
(defun f:vltblobjname (tbl nam doc)
(if (not doc)(setq
doc (fx:doc)))
(if (and
(= (type doc)
'VLA-OBJECT)
(vlax-property-available-p doc tbl)
);and
(f:vlerr
'vla-Item (list (vlax-get-property doc tbl) nam) nil)
(defun
fx:acad ()
(setq
*AutoCAD-application-object*
(cond
(*AutoCAD-application-object*)
((vlax-get-acad-object))
(T
nil)
(defun fx:doc ()
(setq
*active-document*
(cond
(*active-document*)
((vla-get-ActiveDocument
(fx:acad)))
(T nil)
(defun f:vlerr (fun lst tag /
ret)
(if (vl-catch-all-error-p (setq ret (vl-catch-all-apply fun
lst)))
(if tag
(progn (strcat "\n" (vl-catch-all-error-message ret))
nil)
nil
(if (not ret) (setq ret T) ret)
(if (= (type ret)
'VL-CATCH-ALL-APPLY-ERROR) (setq ret nil))
ret)
(defun
f:map_all:filter (filt :fun / ret)
(if (setq ss (ssget "_X"
filt))
(mapcar (function (lambda (e)
(setq ret (append ret (list
(:fun (f:enx e)))))
(f:sstolst
ss)
);mapcar
);progn
);if
(vla-get-Blocks (fx:doc))
(function (lambda (b)
(if (and
(vla-get-IsLayout b) :vlax-false)
(= (vla-get-IsXRef b) :vlax-false)
(not
(wcmatch (vla-get-Name b) "*|*"))
);and
b
(if (f:apply_ssfilter e filt)
(setq ret (append
ret (list (:fun
e))))
);if
);map
);if
));function
);map
ret
(defun
f:sstolst (ss / lst i l)
(if ss (progn
(setq l (sslength ss) i
0);setq
(while (< i l)
(setq lst (append lst (list (ssname ss i))) i
(1+ i))
);while
));progn if
lst
(defun f:apply_ssfilter (en
lst / ret val typ)
(setq ret T en (f:en en))
(mapcar '(lambda (at)
(if
ret
(cond
((= (car at) 0)
(if (not (wcmatch (setq typ (strcase (f:assoc
0 en))) (strcase (cdr at))))
(setq ret nil)
);0
((member (car at)
(list 8 2));layer or blockname
(if (not (and (= (car at) 2) (/= typ
"INSERT")))
(if (not (wcmatch (strcase (f:assoc (car at) en)) (strcase (cdr
at))))
(setq ret nil)
);layer blockname
((= (car at)
-3)
(if (not (assoc -3 (entget en (cadr at))))
(setq ret
nil)
);xdata appid - this will not work in a dbx dwg
((setq val
(setq ret (= val (cdr at)))
(T (setq ret
nil))
);cond
);if
lst
ret
i found it herehttp://forums.autodesk.com/t5/AutoCAD-2008/change-base-point-of-a-block/m-p/2458376/highlight/true
Edited by Tiger
added code tags
