Autocad 2023 was working fine and suddenly  after i open it and click anything it freezes without giving any errors. I tried repairing and reinstalling also tried different version (autocad 2024 and autocad 2022) they are all making the same problem please help me
Is this at work or at home?
Operating System, computer and graphics card/driver specifications?
Do any other programs have any problems?
Did you read this?
Thank you for replying.
Its only happening with autodesk autocad
I have windows 11
Laptop is asus rogstrix
Rtx 3050 and 16gb rams
However i tried to create a new user and on the new user all works perfectly but on my main one im still having the same problem in case this information helps. Waiting for your reply thanks again
Like SLW210 pretty sure had this problem once and it was that the copy was not licensed with Autodesk, had to go to the Autodesk/manage web site and do the registration then it worked.
  • 1 year later...
I had this happen recently! If clearing the cache doesn't work, try right-clicking your AutoCAD desktop shortcut, go to Properties > Open File Location, and find the AcSignApply.exe file.
If you disable the digital signature verification there, it can stop AutoCAD from hanging while it tries to verify certificates through a firewall. It's a weird fix, but it's a lifesaver for older versions.
