when i write text like %%uMR MAN%%u the line under text appear not straight WHY?
is your text non-straight as well? Have you tried a Regen/Regen All? Does it happen all the time?
yes i tried it but it doesn't work
It might be a viewing error induced by the resolution of your monitor. The real test should be does it plot straight?
also make sure that the rotation of the text is 0.00000000000...sometimes, depending on your units set up, it may read 0.00 but maybe it's really 0.0001 or something...just a thought...
How does it plot? Like ReMark said, it might just be a viewing problem.
If you draw a line with ORTHO on, does that appear straight :?
What the properties of the text when selected ??
when i draw line with ortho on line appear straight BUT line under text still not straight
