im using AutoCAD 2007 and need to open this file in cad can someone help me?
Try opening it with a text editor, I believe it is an ASCII file with survey points.
If it's not a ".dwg" file you can't open it in cad.
Do you mean you need to create points in your drawing based on the survey data? That's quite a different matter. You'd need to use an add-on program like Civil 3D, LDD, etc, especially if you need to work with the points. if you just need point objects there are a lot of lisp routines that can do this.
  • 10 months later...
Any ideas how to open an ASC file? Contains windspeeds.
I have AutoCAD, C3D & solidworks.
Colleague wants to import to Google Earth I beleive.
  • 3 weeks later...
Pleae , I need help how to open asc files with windspeeds datas in. What to use in order to open it. Help needed:(
paste it here first I know of an asc file and its not a windspeed file.
Also what do you actually want to do ?
You have not told us. Sure we can open it and read it within autocad !
I can not put file becouse is to big. As a zip file , size is 9MB.
Cut a few lines out of it and paste here use word etc which can open big files.
make sure you paste the first few lines often there is a header line first.
