td88 Posted March 24, 2009 Posted March 24, 2009 Is there a way to change the leader arrowhead size without changing the diimension arrow/tick size? Quote
tzframpton Posted March 24, 2009 Posted March 24, 2009 Is there a way to change the leader arrowhead size without changing the diimension arrow/tick size? I don't know if it works for LT, but hit Enter before placing the 1st point of the leader, and it'll bring up the Leader Options. Quote
Ritch7 Posted March 26, 2009 Posted March 26, 2009 am i missing something , you can do this via selection properties Quote
td88 Posted March 26, 2009 Author Posted March 26, 2009 Thanks, Ritch. I'm looking for a setting I can use to set the arrowheads at a certain size, prior to placing, and not have to go back and change each arrowhead or use match properties after I've placed them. If I'm not mistaken, Properties changes each head, one at a time and is not a setting. Quote
tzframpton Posted March 26, 2009 Posted March 26, 2009 Thanks, Ritch. I'm looking for a setting I can use to set the arrowheads at a certain size, prior to placing, and not have to go back and change each arrowhead or use match properties after I've placed them. If I'm not mistaken, Properties changes each head, one at a time and is not a setting. A LT user asked me this same question today so I verified it. Just hit Entire before placing the first leader, this will bring up the Leader Options dialog box. Once you set it, you're good to go from then on. Other than that make a Dim Style to reflect how you want it. Quote
td88 Posted March 26, 2009 Author Posted March 26, 2009 StrykFace, I do get a settings box, when I click enter but, it 's the same box I get when I enter S, after invoking Quick Leader. Neither settings box offers an arrowhead size option. Makes no sense. Why would they tie dim.'s to leaders? Quote
tzframpton Posted March 26, 2009 Posted March 26, 2009 StrykFace, I do get a settings box, when I click enter but, it 's the same box I get when I enter S, after invoking Quick Leader. Neither settings box offers an arrowhead size option. Makes no sense. Why would they tie dim.'s to leaders? ah, yeah you'll need to make a Style then. or create an arrowhead block and make a custom size, then add it to the dimstyle. Just the way it goes sometimes.... Quote
Tankman Posted March 27, 2009 Posted March 27, 2009 Is there a way to change the leader arrowhead size without changing the dimension arrow/tick size? Change/modify the first one, match properties on any additional leaders. Do you have a zillion leaders? Keep it simple, smart. Quote
Print_Master Posted July 19, 2012 Posted July 19, 2012 Go to format drop down menu. Click on Multileader Styles. Click modify. This will bring up the Modify Multileader Style: "" where you can change the settings for all the M-leaders you have on your Dwg. Quote
tzframpton Posted July 24, 2012 Posted July 24, 2012 Mleaders are not the same as Qleaders.Not to mention the unnecessary resurrection of a 3 year old thread. Quote
