Would appreciate some help in the steps needed to align the end of my 3d drawing. I aligned one end.It should end up tapered. Thanks for all replys. Useing autocad 2009
autocad2.dwg
You can use the following steps:
1. create 2d cross sections of the top part and the bottom part, split those rectangles in half and type "bo" it will allow you to create boundaries, make boundaries of those objects, total of 4 boundaries should be created, 2 form the bottom cross section and 2 from the above cross section, something like this:
then go into 3d modelspace, align the parts (i used the red lines just as a guide to know where the center is), move the top part along Z axis as high as you need, then type "loft", select the top and bottom sections, use "cross sections only" option, and accept to initiate the command, it should look something like this
After that "loft" the remaining two parts, then you can optionaly use the "UNION" command to join them in one solid object, if needed, if you want, you can also make it from 4 parts using the same procedure and make somethng more like in your drawing.
Hope this was of some help!
... steps needed to align
Align Enter
F1
3dAlign Enter
F1
Ditto what J.D.M. mentioned. My recommendation would be to use a minimum of at least two points for accurate placement.
