How to force an ENTER after typing a value to a command
Hello,
I am writing an auto lisp script to draw leaders from an object to point to other items, (see part of the script below). I want to know if there is any way that after I press "Y" (Yes) to avoid the need to hit enter so the program ask me for the "Connect to:". I will appreciate your help. Thank you!! :D
(setq ldr2 "Y")
(while (= ldr2 "Y")
;-- Get the leader point & draw it
(setq pt1 (getpoint ip "\nConnect to: "))
(setq pt2 (polar ip (angle ip pt1) 0.1625)) ;--This is the pt on the BOM circle
(command "_line" pt2 pt1 "")
;-- Ask for another leader
(initget "Y")
(setq ldr2 (getkword "\nDo you need an extra leader? (Y/N): "))
Why not just use a default, so that the user only has to hit enter?
A default can be specified like this:
(or ldr2 (setq ldr2 "Yes"))
(initget "Yes No")
(setq temp (getkword (strcat "\nDo you need an extra leader? (Y/N) <" ldr2 ">: ")))
(or (not temp) (setq ldr2 temp)))
Check getkword its what you want
to quote lisp manual
(initget 1 "Yes No")
(setq x (getkword "choose Yes or No" ))
The case I think can give two answers Y v's y the capital I think in "Yes" makes it work if you add other words as lower case they may not work as you would have thought.
Some variations:
  (initget "Yes No")
 (setq return (cond ((getkword "\nQuestion: Yes/No/<Yes>:"))
                    ("Yes")))
    (INITGET 0 "Yes No")
   (OR (SETQ return (GETKWORD "\nAre you sure? [Yes/No] < Yes >: "))
       (SETQ return "Yes")
(DEFUN c:Yesno (/ return)
 (initget "Yes No")
          ("Yes"))
I prefer the /= test for that scenario
(initget "Yes No")
(if (/= "No" (getkword "\nDo this?  (Yes/No)  <Y>:   "))
   (yayda_yada))
-David
Some good examples guys ^^
But they don't remember the last entered option... :P
Lee Mac, I used your code, but I still have to hit enter after I enter "N" if I decide not to have any more leaders. What I am looking for is to make the "Y" or the "N" an automatic value for the function so it takes it as a "response plus the enter" together without needing to press enter everytime I enter "Y" or "N".
I realise this, but I doubt that you can avoid hitting enter in this circumstance.
Why not just use the while statement like this:
(while (setq pt1 (getpoint ip "\nConnect to: "))
 (command "_line" pt2 pt1 ""))
OK, here is my One Key Press routine like GetKword.
I made it somewhat generic.
;;  GetKeyPress.lsp
;;  CAB  version 1.0  03/26/09
;;  Get one key press from user similar to GetKword
;;  keys = list of key char & return value  '(("Y" "Yes")("N" "No"))
;;  def = result if ENTER is pressed  nil or "Yes" or "No" etc
;;        if nil then Enter is dissallowed
;;  msg = the prompt nil = "Press a key"
;;  emsg = the error message nil = "Incorrect keypress."
(defun GetKeyPress (keys def msg emsg / input result)
 (or msg (setq msg "Press a key"))
 (or emsg (setq emsg "Incorrect keypress."))
 (princ (strcat "\n" msg))
 (while (null result)
   (and (= (car (setq input (grread))) 2) ; keyboard entry
        (< 31 (setq input (cadr input)) 255) ; a key was pressed
   (cond
     ((listp input)) ; not a keypress
     ((setq result (assoc (strcase (chr input)) keys))
      (setq result (cadr result))
     ((and (= input 13) def)
      (setq result def)
     ((princ (strcat "\n" emsg "\n" msg)))
 result
(defun c:test(/ ans)
 (setq ans (GetKeyPress
             '(("Y" "Yes")("N" "No"))  ; keys allowed, not case sensitive, & return value
             "Yes" ; default when ENTER is pressed
             "Do you need an extra leader? (Y/N) [Yes]:" ; message prompt
             nil ; use default error message
 (princ ans)
Thank you CAB!! So how do I call that function in my code? I got confused now :oops:
This is my complete code:
(defun c:bom ()
(command "-osnap" "")
(command "ortho" "Off")
;-- Get the parameter reqd to insert the BOM block
(setq ip (getpoint "\nInsertion Point: "))
(setq int1 (getint "\nItem Number: "))
(setq st1 (getstring "\nLeft Text: "))
(setq st2 (getstring "\nRight Text: "))
;-- Set layer to TEXT
(command "-layer" "set" "TEXT" "")
;--Insert the block with the given params
(command "_insert" "bom" ip "" "" "" int1 st1 st2)
(setq ldr2 "Y")
(while (= ldr2 "Y")
I THINK I HAVE TO CALL YOUR FUNCTION HERE BUT I AM NOT SURE NOW HOW TO CALL IT :oops:
;-- Ask for another leader (original code)
(initget "Y")
(command "-layer" "T" "0" "ON" "0" "set" "0" "")
Thank you!
Try this:
(defun c:bom ()
 ;;-- Get the parameter reqd to insert the BOM block
 ;;-- Set layer to TEXT
 ;;--Insert the block with the given params
 (setq ldr2 "Y")
 (while (= ldr2 "Y")
   ;;-- Get the leader point & draw it
   ;;--This is the pt on the BOM circle
   ;;-- Ask for another leader (original code)
   (setq ldr2 (GetKeyPress
                '(("Y" "Yes") ("N" "No")); keys allowed, not case sensitive, & return value
;;  GetKeyPress.lsp
   (cond
      (setq result def)
 result
Thank you CAB,
I loaded the code but I still can't get it to run whenever the function asks me for another leader it ends the function pressing "Y" or "N" or "enter". I can't find what am I doing wrong.
Try this Ham,
I have included an Error Handler and have updated the variable setting and included coding to accomodate for user errors.
(defun c:bom  (/ *error ovar vlst ip int1 st1 st2 ldr2 pt2)
 (defun *error*  (msg)
   (if    ovar
     (mapcar 'setvar vlst ovar))
   (princ (strcat "\nError: " (strcase msg)))
   (princ))
 (setq    vlst '("CMDECHO" "ORTHOMODE" "OSMODE" "ATTREQ" "CLAYER")
   ovar (mapcar 'getvar vlst))
 (mapcar 'setvar (cdr (reverse vlst)) '(1 0 0 0))
 (if (not (tblsearch "LAYER" "TEXT"))
   (command "-layer" "m" "TEXT" "")
   (setvar "CLAYER" "TEXT"))
 (if (findfile "bom.dwg")
     (if (and (setq ip (getpoint "\nInsertion Point: "))
          (not (initget 5))
            st2  (getstring "\nRight Text: ")))
     (command "-insert" "bom" ip "" "" "" int1 st1 st2)
     (setq ldr2 "Yes")
     (while (and (= ldr2 "Yes")
             (setq pt1 (getpoint ip "\nConnect to: ")))
            '(("Y" "Yes") ("N" "No")) ; keys allowed, not case sensitive, & return value
   (princ "\n<!> Block Information Not Correct <!>")))
   (princ "\n<!> Block Not Found <!>"))
 (princ))
;;  GetKeyPress.lsp
   (cond
      (setq result def)
 result
Oops, I left out the code to prevent it from being case sensitive.
Revised version:
;;  GetKPress.lsp
;;  keys = list of key character & return value not case sensitive
;;          '(("Y" "Yes")("N" "No"))  Note that the key character must
;;          be a string but the return value may be any data type
;;        (any data type) if nil then Enter is dissallowed
(defun GetKPress (keys def msg emsg / input result klst)
 (mapcar '(lambda(x) (setq klst (cons(list(strcase (car x))(cadr x)) klst))) keys)
   (cond
     ((setq result (assoc (strcase (chr input)) klst))
     ((and (= input 13) def) (setq result def))
 result
Wow!!!! You are amazing CAB!!! The code seems kind of complicated but I went through it and now I understand a lot more. Thank you!!!
Have a great day!!!
Thank you Lee Mac I appreciate your help!!! You guys are amazing!!!
No probs :) - I do need to study the grread function in a lot more detail - I have only used it once or twice myself, but it is such a powerful command to invoke when you know how to use it properly ;)
Cheers guys,
Lee
