LISP Routine to change a 2D Polyline (PL) elevation to match the elevation of a cogo point
Hey everyone,
I'm curious to know if anyone can assist with producing a lisp that will allow a user to click on a cogo point in a drawing, then copy the elevation from the cogo point and then click on a PL and assign the copied elevation from the cogo point to the selected PL.
Thanks.
Can you attached example drawing
This is read a cogo point example, you could then assign the elevation property to that value.
; get X Y Z of a cogo point
; By AlanH
(defun CIV3DPTHT ( / obj oldtext oldlay xyz pt1 ht pt)
  (alert "Pick CIV3D points press ESC or pick nothing to exit")
  (while (setq obj (vlax-ename->vla-object  (car (entsel))))
 ; vl 3d point convert to plain lisp
  (setq pt1 (vlax-safearray->list (vlax-variant-value (vlax-get-property obj "Location"))))
  (setq ht (rtos (nth 2 pt1) 2 3)) ; Z val
  (setq pt (list (nth 0 pt1)(nth 1 pt1))) ; XY
  (setq oldtext (getvar "textstyle"))
  (setq oldlay (getvar "clayer"))
  (command "Layer" "n" "Pointhts" "c" 1 "Pointhts" "s" "pointhts" "") ; put text on new layer
  ; 2.5 annotative text
  (if (setvar "textstyle" "ISO2.5")
      (command "TEXT" pt 0 ht)
      (alert (strcat "The style ISO2.5 annotative does not exists" "\nplease create and run again"))
  (setvar "textstyle" oldtext)
  (setvar "clayer" oldlay)
) ; end while
) ; end defun
(CIV3DPTHT)
So you want to make a 3dpolyline picking multiple points is that correct ?
I think you haven't searched for enough solutions but I think this just fits your problem, I tested it and it also works for COGO points.
