Someone can give me a tip how to write a lisp routine that cut with base point the selected objets and then paste as block asking for insertion point ?
Thanks in advance
You can use the keys Ctrl-Shift-V to Paste as Block. Don't re-invent the wheel.
Edit: There is an explicit command PASTEBLOCK as well.
Edited by CyberAngel
Thanks.
i'm aware of this commands.
I just wanted to have the completed task in one command to improve the time spent in several equal tasks.
On 8/6/2024 at 9:41 AM, mike_ribeiro said:
Thanks.
@mike_ribeiro
There are the commands COPYBASE and CUTBASE built in to AutoCAD to get the selection point. No LISP needed, but if you must:
(defun c:cutpaste ()
   (command "._cutbase")
   (while (= (logand (getvar "cmdactive") 1) 1)
		(command pause)
   (command "._pasteblock")
Although - how is this different from the MOVE command? OK - so I guess it makes an anonymous block immediately.
Edited by pkenewell
