Mr.Alex Posted March 26, 2009 Posted March 26, 2009 Hi, I'm slowly switching from Microstation to AutoCAD. I'm trying to find out if a tool that exists in Microstation exists in AutoCAD. In Microstation, it's called the 'snap point divider'. It's like the 'snap to midpoint' command in AutoCAD, but you can enter how many divisions of the line youd like, you don't just have to snap to a line's midpoint. So for example, if you selected 3, you could snap to a line at a point a third of a way along it. Or you could select 10,50, whatever. I hope that makes sense! If it does make sense, can anyone tell me if that tool exists? Thanks Quote
uddfl Posted March 26, 2009 Posted March 26, 2009 No, but it sounds good though. Via the command OSNAP (or +DSETTINGS 2) you will find a list of the standard snap tools in AutoCAD. The closest you'll get with plain AutoCAD is the DIVIDE command but it's nowhere as quick as what you describe. Quote
Mr.Alex Posted March 26, 2009 Author Posted March 26, 2009 Ok, thank you. It's a shame there's no exact equivalent, it's a usefull tool Thanks for the suggestions, I'll have a look at them! Quote
uddfl Posted March 26, 2009 Posted March 26, 2009 Ok, thank you. It's a shame there's no exact equivalent, it's a usefull tool Thanks for the suggestions, I'll have a look at them! I am thinking there might be a way to do it using the transparent 'CAL command... similar to how you find the mid point between two other points, e.g.: 'CAL (END+END)/2 I tried with other values instead of /2 but did not get the correct point returned... Quote
ReMark Posted March 26, 2009 Posted March 26, 2009 Would this Lisp routine do in a pinch? http://cadtips.cadalyst.com/2d-operations/divide-open-areas Quote
Mr.Alex Posted March 26, 2009 Author Posted March 26, 2009 I'm not familiar with the 'cal command, I'll look into that, thanks. Thanks for the suggestion of the divide command, I had a go with that, and while it's not as quick as what I was looking for, it's pretty close Quote
Mr.Alex Posted March 26, 2009 Author Posted March 26, 2009 Would this Lisp routine do in a pinch? http://cadtips.cadalyst.com/2d-operations/divide-open-areas Sounds very clever!! I've not played with Lisp routines either yet, I'll look into that too. Thank you Quote
