MarkCalvert Posted March 27, 2009 Posted March 27, 2009 Hello All, I am having some issues with some Xrefs in my office. There is a drawing with an Xref, it shows with no problem on my computer, which has AutoCAD 2005, however on someone elses computer it misses information out, even with all the layers turned on there are sections missing. This machine is AutoCAD 2005 LT. Thank you for any help and responses. Mark Quote
42 Posted March 27, 2009 Posted March 27, 2009 Couple of this to check. Are you looking at the xref in model or paper space? If in PS then check that the layers within the PS viewport are turned on. Does the xref look the same in PS and MS? Quote
MarkCalvert Posted March 27, 2009 Author Posted March 27, 2009 Couple of this to check. Are you looking at the xref in model or paper space? If in PS then check that the layers within the PS viewport are turned on. Does the xref look the same in PS and MS? It looks the same in any viewport. However, when the actual drawing is opended, (the one that becomes the Xref) it shows the same parts missing. However on my machine it shows everything. I hope that makes sence! Quote
Cad64 Posted March 27, 2009 Posted March 27, 2009 Does the machine with LT have all available object enablers loaded? Quote
MarkCalvert Posted March 27, 2009 Author Posted March 27, 2009 No, it doesnt. I will give this a try! Quote
Peter K Posted March 27, 2009 Posted March 27, 2009 If that didn't help .... then I can't help but wonder if one has to start thinking along the lines of xref clipping that went quirky. Quote
