SLW210 Posted November 27, 2007 Share Posted November 27, 2007 My 2008 locked up while trying to _WBLOCK it. I will give it another look tomorrow. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted November 27, 2007 Share Posted November 27, 2007 Seems like it works fine in 2000i and 2005, but locks up 2008. You may need to contact Autodesk and see if they can sort it since it appears it is a 2008 only problem. As of Wednesday of last week, I have the latest updates on my 2008. Quote Link to comment Share on other sites More sharing options...
riga Posted November 27, 2007 Share Posted November 27, 2007 Seems like it works fine in 2000i and 2005, but locks up 2008. You may need to contact Autodesk and see if they can sort it since it appears it is a 2008 only problem. As of Wednesday of last week, I have the latest updates on my 2008. That's exactly what I think. After an audit in 2007 it works apparently without problems, but in 2008 there's no way to get it work.... Maybe it is really usefull to contact Autodesk > pheraps a fix to include in SP2 Quote Link to comment Share on other sites More sharing options...
SLW210 Posted November 27, 2007 Share Posted November 27, 2007 That's exactly what I think. After an audit in 2007 it works apparently without problems, but in 2008 there's no way to get it work.... Maybe it is really usefull to contact Autodesk > pheraps a fix to include in SP2 I got it to work without freezing up by saving as a R12 .dxf, but the dimensions were all f'd up. Might could do some more stuff to get it to work, but just not worth the effort. I finally got it _WBLOCKED, but that was still freezing up. Also Opened it with DWG TrueView 2008 and DWGGateway and saved as different formats, still not working in 2008. Quote Link to comment Share on other sites More sharing options...
saravanan Posted May 31, 2008 Share Posted May 31, 2008 while working on the program it's not responding program hang 1 GB ram , autocad 2009 give me solution Quote Link to comment Share on other sites More sharing options...
SEALAM Posted December 18, 2008 Share Posted December 18, 2008 i have had computer at work from new with 2009 inventor has always had graphics missing and freezing and shut downs ,so far i have changed hard drive graphics card and all drivers and computer has been reformatted but still have same problems it also freezes when inventor is not running when using excel and other documents only thing i have thought of is replacement of mother board as last resort . does any one have any ideas as to why i have these problem ,i also use program at home on 2 other computers but do not have problems but they are older and do not go as quick Quote Link to comment Share on other sites More sharing options...
bagulhodoido Posted December 30, 2008 Share Posted December 30, 2008 I had this problem once, I was using a 2004 version, and the drawing was made on a 2008 version and after done they changed it to a compatible version. Every little thing I tried to do kept freezing the whole program. Solution? A new autocad version worked just fine. Quote Link to comment Share on other sites More sharing options...
LifeoRiley0 Posted December 30, 2008 Share Posted December 30, 2008 I also had the originally posted drawing lock up autocad on my computer. Quote Link to comment Share on other sites More sharing options...
